Thread: need to know is this the one i need??
    Full Member baines23's Avatar
    Oct 2012
    Dudley
    Vehicle : 2004 sxi
    Engine : 1.8
    Smile need to know is this the one i need??
    looking to get egr blanked out, and with a remap within next 2 weeks , from Mas after seeing the amount of reviews on here , just wanted to make sure this is pretty much the type of blanking plate that would sort it ?
    http://www.ebay.co.uk/itm/EGR-valve-...10782318801%26
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    That's a semi blanking plate. If you're getting the egr mapped out, best go for the full blanking plate without the centre hole.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    103 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Yep, ideally need the one without a hole in the middle. But unless your EGR valve is stuck partly open, you can get away without a blanking plate at all, because the EGR valve will remain closed all the time after the remap anyway.
    I've mapped out my egr but never bothered with a blanking plate - works perfectly and opcom shows valve always closed.
    Oct 2012
    Dudley
    Vehicle : 2004 sxi
    Engine : 1.8
    thanks guys, just was not to sure about it so fought id ask, sound
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Do you need new gaskets for these or can you just unbolt, fit this and bolt back on? Only reason I ask is I have one waiting to go on but the eBay listing I got mine from said you need 2 gaskets (1 either side of the blanking plate, is that right?
    woodbridge, suffolk
    103 Post(s)
    Trim : Design+
    Mileage : 101000
    Yes, you need two new gaskets - one each side of the blanking plate.
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    You dont need any gaskets on
