Thread: 2 Errors (Fuel Filter Heater Circuit Open & Exhaust Gas Temperature Sensor need advice
    Jan 2013
    Reading
    Default 2 Errors (Fuel Filter Heater Circuit Open & Exhaust Gas Temperature Sensor need advice
    Hi i have two errors coming up on my op-con
    P1180 - Fuel Filter Heater Circuit Open
    (04) - Present
    P1902 - Exhaust Gas Temperature Sensor High Voltage (Bank 1 Sensor 2)
    (05) - Present
    Could someone point me in the right direction on what needs replacing?
    Thanks allot
    I'm also using the search function on the site to try and find the solution
    On a side note i have just replaced the battery and alternator as they were both faulty. So hoping this might have something to do with them.
    Engine : 1.9 CDTi
    Have you rest them too see if they come back?
    Jan 2013
    Reading
    I had the ecu reset before i replaced the battery and alternator and same errors came up.
    Will having a reset next week. Just thought i would ask before reset incase garage tries to bend me over a barrel.
    (i have ran a fault clear on the op-con but that does not clear them)
    Jan 2013
    Reading
    I would also like to say when my alternator went i did get additional codes but they came up as "Not Present"
    A reset with the op-con and the codes disapeared.
    I've just been pointed into the direction of this thread
    http://www.vectra-c.com/forum/showth...ighlight=p1180
    looks like i have allot of cleaning ahead. Glad i have tomorrow off work
    The main reason i need to get these two fixed is that it's drinking fuel. Costing me even more than my 1.8 petrol vectra B did.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    what year and model do you have?
    Jan 2013
    Reading
    Its a 1.9 cdti sxi 54 plate.
  1. Exhaust Gas Recirculation Circuit Open
    By john norris in forum Engine & Drivetrain
    Last Post: 16th October 2012, 12:56
  2. Replies: 3
    Last Post: 13th August 2012, 22:25
  3. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  4. p0335 crankshaft sensor open circuit
    By jon1.9cdti in forum Engine & Drivetrain
    Last Post: 28th July 2010, 11:52
  5. Oxygen Sensor Heater Circuit Voltages?
    By marcdale in forum Engine & Drivetrain
    Last Post: 31st May 2009, 21:28
p1902-05 exhaust gas temperature sensor high voltage bank 1 sensor 2
opel fault p1902 www.vectra-c.com
p1180 vauxhall zafira fuel filter heater open circuit
vectra c fue filter heater fault
vauxhall zafira p1902 fault and fix
p1180 opel
