Results 1 to 2 of 2
Thread: Split pipe? Which one is the intercooler?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Default Split pipe? Which one is the intercooler?
    I've noticed that the car sounds like it has an air leak somewhere, like a pipe has split etc...
    It starts fine and turbo etc spoils up as it should, until it reaches 2k revs under load and then the engine sound like its blowing and gets really loud! I've never noticed it before, but I also dont drive it very often. The noise isnt there at idle, just a slight shudder/wobble from the engine. No fault codes or dash lights.
    So, can someone tell me which is the intercooler and the locations of the pipework I need to look at?
    Is there anything you can spray into the air intake to see if it escapes anywhere?
    Facelift CDTI 120
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    HI chunklamb,the intercooler is the radiator look alike mounted in front of the main radiator,check the bottom edge of the intercooler as they have a habit of splitting,also check the hoses leading from the turbocharger to the intercooler (both sides)
    the best way is to let someone keep a few revs on whilst you listen from under the bonnet,you should be able to feel the air bypassing if you run your hand over the hoses and intercooler,be carefull though as the engine and air is hot after it has passed through the turbo
  1. Split pipe
    By LeeU in forum Diesel Engine related
    Last Post: 10th September 2011, 20:38
  2. split pipe
    By pacman696 in forum Engine & Drivetrain
    Last Post: 6th June 2011, 21:04
  3. What causes an intercooler to expand and split guys??
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 22:51
  4. split intercooler!!!!
    By wrayballs10 in forum Diesel Engine related
    Last Post: 12th January 2011, 08:40
  5. Split pipe or is it worse?
    By cookie in forum Engine & Drivetrain
    Last Post: 19th May 2010, 22:14
vectra cdti 120 intercooler where is it www.vectra-c.com
split in inter cooler on vauxhall vectra
