Thread: Abs light ?
    Jan 2013
    Birmingham
    Default Abs light ?
    Abs light came on the other day but went off after a couple miles today it's came back on and has stayed on any idlers ?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    probably best have it plugged in , see what codes are present.
    Regular Member stret's Avatar
    Oct 2012
    east midlands/westmidlands
    27 Post(s)
    Vehicle : signum
    Trim : elite
    Engine : 1.9 cdti 16v 225bhp
    Year : 54
    Mileage : 150k
    mine did this and it was diagnosed and came up as near side front abs sensor defective so i had it replaced but still had same problem abs light on and fault wouldnt clear anyway traced the wire back and it was corroded so cut and re soldered it and hey presto light went out but then when it was wet the light was coming back on again so i guess moisture was still getting in n messing the readings up n throwing the fault up so went scrap yard cut the wire back from as far as i could get behind the arch cut mine out re soldered the new one in shrink wrapped it and covered in a sealent n all is well this was 3 months ago now
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    have a look at post 4
    http://www.vectra-c.com/forum/showth...light=wd40+abs
    normally a plug that notoriously gets water in and corrodes the terminals and a poor contact is thus made.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Can relate to low brake fluid.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    broken wire loose connection
    Regular Member rickisgrate's Avatar
    Jan 2012
    Ayrshire
    Mine did this, 6 days in a "specialist" garage and discovered it was the toothed ABS ring that was knackered. Thank god it was still under warranty
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
