Thread: Oxygen sensor removal
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default Oxygen sensor removal
    Hi guys changing my exhaust today as the flexi is leaking and can't get the oxygen sensor out, have tried heating it up also let the car run for a bit bit of heat in the exhaust but it just wont budge, Any tips for removing the sensor much appreciated
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Good 22mm ring spanner and soak it in penetrating fluid
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    An O2 sensor socket and a bar
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by Critch View Post
    Exactly that...
    You will round it off using a 12point (normal) ring spanner. You need a 6 sided socket..
    Draper 55540 Expert 22mm 38 Square Drive Oxygen Sensor Socket
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Took it to the local garage in the end who got it out and fitted the new exhaust on for £10 so not to bad, going to invest in a oxygen sensor socket thanks guys
  1. Lambda / Oxygen Sensor
    By R-man in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2012, 21:13
  2. oxygen sensor
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 2nd December 2011, 23:25
  3. Oxygen sensor!!!!
    By darrenmac in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 16:53
  4. Help re Oxygen sensor for Z32 SE V6
    By the-converter in forum Engine & Drivetrain
    Last Post: 29th September 2009, 15:31
  5. oxygen sensor
    By pipamish in forum Engine & Drivetrain
    Last Post: 20th June 2008, 20:43
vectra c remove lambda
