Thread: vectra c 2.0 DTI 2004 clutch plate help!!!
    Nov 2009
    notts
    Question vectra c 2.0 DTI 2004 clutch plate help!!!
    hi guys its been a while!
    i need some help, i fitted a new clutch kit today to the vec all went well until i went to pull it out of the garage.....
    clutch wasn't clearing!
    one thing i wasn't sure about was the way round the clutch plate went? i noticed the splined part in the center of the plate stuck out further on one side than the other, i just need a clue as to which way round is right!
    any help would be greatly appreciated,
    thanks ashley
    scotland
    sticky out bit faces outward away from engine I believe , but if you got it in wrong way just switch it round if you are dismantling again .
    Nov 2009
    notts
    thanks mate i think thats whats gonna have to happen.
    i always thought that was the way round they went but now not too sure.
    spent ages bleeding aswell just to be sure, the fluid that was coming out was black!
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    can't remember 100% from when I did mine but seem to think the thicker part went towards the flywheel .
    Regular Member wingi's Avatar
    Dec 2012
    clipstone
    usually the thicker sticky out bit faces the gearbox and there should be enough room inside the pressure plate for the thicker part. i think you have put the friction plate in the wrong way round. when you take the box back out and remove the clutch make sure the friction plate moves easily on the splines on the gearbox!!!!
    Nov 2009
    notts
    thanks for your replies guys, after alot of messing around a new concentric slave cylinder and practically doing the whole job again, i found i had indeed fitted the plate the wrong way round! the thicker side actually went to the flywheel!
    lesson to be learned for me there...... if in doubt ask someone else lol
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    look closely it should say it should say gear box side or engine side maybe in german though
    i done the wifes zafi last year i changed everything even the crank seal when i gad the clutch off
    May 2012
    county durham
    Mileage : 145k
    Quote Originally Posted by ash0402 View Post
    like I said in earlier post but wasn't 100% , this is the reason people make mistakes , clutches have always had thick part to gearbox side & then suddenly it changes .
    Nov 2009
    notts
    Quote Originally Posted by DTi Elite View Post
    yep everyone iv done in the past has been thick side to gearbox! so i took a chance that didnt pay off!
    May 2012
    county durham
    Mileage : 145k
    bit of a ****er having to take it apart again but we live & learn .
  1. Replies: 0
    Last Post: 25th September 2012, 13:44
  2. Clutch pedal to the floor vectra 1.8 52 plate
    By chubbs21 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 00:35
  3. vectra c 2004 1.8ls CLUTCH GONE / DMF?
    By liam8282 in forum Engine & Drivetrain
    Last Post: 8th June 2011, 13:46
  4. 2004 54 plate vectra c sri cdti 150 bhp
    By davidjameswest in forum Cars for sale
    Last Post: 18th July 2009, 20:28
  5. 2004 04 Plate 2.0T SRI
    By Cerealuk in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 25th November 2008, 18:53
1.9cdti clutch plate wrong way
what way does a friction plate go on a vectra 2.0 dti
vectra 1.9 cdti what way round does the friction plate fo
vectra 1.9 cdti luk friction plate gearbox side
which way does the clutch plate on a 2005 vectra go in
which way do you put the clutch plate on a vauxhallvectra
