Results 1 to 3 of 3
Thread: Help?
    manchester
    Unhappy
    i've got a 2002 vectra 1.8 ls from new its done about 65,000 miles but for the last few months the cars goes slightly to right but not all the time i got it re-blanced but no luck theirs like a creaking noise coming from the steering rack or something it only dose the sound sometimes when i break i had a look under the car i found a leak i think its power steering fulid i put more power steering fulid in its just made the steering more smooth i even went as far as changing the rod ends but still no luck. could this be from wishbones or something or can it be from the steering rack? any help would be appreciated. thanx oz
    p.s sorry about my spelling my english isn't that good
    the car also feels rely bad to drive even at 30mph its even worse on the moterway i can't get go over 55mph cos the car will move to right even when am holding the steering wheel its bad when its windy its get to dangerous to drive. wot can this be from?
    I'd start off by getting the tracking checked at a garage.. that will tell you if it's all in line..if it's not that that is making the car go right all the time thenit may well need the steering rack looking at to see if and where it's leaking and if it has any other damage to it..
    the creaking could have been because it is low on fluid..
    This is one you may well have to get a Pro to look at for you..
    manchester
    Default thank you
    thanx to you i got it sorted its was the wishbone and it needed tracking done on it and a new seal put in the streering rack good as new.
