Results 1 to 3 of 3
Thread: what's the difference???
    Dec 2012
    newcastle
    Default what's the difference???
    Following on from my current problem what's the difference between a 2.2 direct engine and a 2.2 non direct engine?? Thanks.
    Dec 2012
    Banbury
    Sorry to add to this on both engines are the alternator the same ??
    Feb 2011
    Selby
    The 2.2 non-direct has the fuel injectors spraying fuel in before the valves. On the 2.2 direct, they spray directly into the cylinders. This requires much more expensive injectors as they have to cope with the heat and pressure of the combustion, but allows a much better control of fuel mixing leading to better economy and more power. Direct injection engines started appearing in the late 1990s and are gradually replacing indirect injection ones. Wikipedia no doubt has some good information on indirect and direct injection.
    Both the Z22SE (indirect) and Z22YH (direct) are basically the same engine, apart from the difference in fuel injection system and heads.
  1. Difference between SXI and SRI
    By mungo1985 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2011, 02:08
  2. de-cat............no difference lol
    By hairy31 in forum Diesel Engine related
    Last Post: 21st September 2011, 22:39
  3. Difference
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2011, 19:53
  4. What's the Difference
    By kns in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2009, 21:24
  5. 19s what a difference
    By kpf1grandprix in forum Handling & Braking
    Last Post: 23rd June 2008, 13:07
