Thread: tensioner pulley?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default tensioner pulley?
    today my steering went heavy and tc & abs light came on. straight away i new the battery wasn't getting charged, the AUX belt is really loose, its still all in place and it does go round when the engine is started but loose, so im guessing its the tensioner pulley at fault. can the tensioner pulley fail, what i mean by fail is so theres no pressure in it (fluid leak) if that makes sence,
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi chris
    sounds like the tensioner damper is faulty,you can check it by turning the hexagon head on the tensioner anticlockwise the tensioner should rerturn to the tensioned position,if not a new unit is required.the dampers have to be stored in the upright position if not they have to be bled by compressing a few times.
    Oct 2009
    Sandwell
    thats what i think, i think its lost its pressure, its only just over a year old when i fitted the last one i compressed it a feww time but i think i compressed it to much because the black cover part leaked and had a hole in so i put some strong glue over the hole, thats why it make me wonder because of that its lost its pressure
    Jul 2009
    Engine : 20 Dti
    thats your problem,they are a sealed unit that let the oil pass through a small port like a shock absorber there should not be a fluid leak externally
    Oct 2009
    Sandwell
    just brought a new on off ebay £30 should arrive Saturday, at least it shouldn't take me aslong as last time lol
    Jul 2009
    Engine : 20 Dti
    yep,the more times you do it the easier it gets he he
    Jul 2009
    Engine : 20 Dti
  1. Air Con Pulley
    By antowens in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2012, 20:58
  2. vectra v6 cdti tensioner pulley
    By Critch in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 21:51
  3. Aux/Drive belt tensioner & pulley replacement
    By Marky in forum Engine & Drivetrain
    Last Post: 5th October 2010, 20:43
  4. Tensioner kit
    By jun in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2009, 20:56
