Thread: Noise from F/O/S wheel when turning left
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Noise from F/O/S wheel when turning left
    Hi everyone,
    I got a slight problem with my car, haven't been using it much lately over the Christmas holidays, as i have had a long break from work . So it has been sat on my drive at least 2/3 days in the rain, and when i have finally come to use it, its only been used to drive half a mile to my local tesco's and back home, so not much driven at all. Now here its the problem, i noticed when i'm turning left, or full left lock on, i can hear a metal grinding noise coming from the F/O/S wheel, i'm sure it wasn't there before the Christmas holiday. Any ideas on what it is?
    Thanks.
    emec#7
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    Could be the back plate rubbing the disc. Mine did this a while back
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As above, or simply due to lack of use corrosion on the disk .
    Jack the car up and spin the wheel if it still makes a grinding noise you may have a stone or similar trapped between the disk and the back plate , but more than likely the later, lack of use .
    and still loving it
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by bobssignum View Post
    I managed to jack the car up, spin the wheel, there is definitely a noise there. Then i jacked up the other side (left side) and spin the wheel, that's more or less the same noise. , The car has been driven about 80 miles now, any corrosion should of cleared up.
    emec#7
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    can you see any corrosion on the disc?also have you checked the disc pads for wear!
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by Spelly View Post
    Thank you very much, problem solved. It was the back plate rubbing on the disc, i manage to push the backplate back slightly and now no more noise, and tested for 4 days so i can now confirm the issue is fixed
    emec#7
  1. Knocking Noise When Turning Wheel
    By sligo_eire in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd June 2014, 05:58
  2. metallic scraping noise when turning left
    By brasch in forum Suspension, Wheels & Brakes
    Last Post: 13th January 2013, 01:07
  3. Chirping noise when turning left
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:50
  4. Front bang/knock noise on turning wheel
    By NPS in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2009, 19:58
  5. vibrating noise when turning left/right
    By valhalla in forum Suspension, Wheels & Brakes
    Last Post: 27th July 2008, 21:55
grinding nois when turning left vectra
vectra noise when turning
inignia noise when turning
insignia grinding noise when turning wheel
vauxhall insignia noise when turning
insignia st grinding when turn left
2015 vauxhall insignia making noise turning left
vectra c 57 noise when turning
grinding noise when turning full lock in insignia
vectra c grinding when turning left
my insignia makes a chafing sound when turning left
my insignia makes a rubbing sound when turning left
