Results 1 to 10 of 24
Thread: turn the key and nothing!!!!!- Wont start
    May 2011
    North Yorks
    Default turn the key and nothing!!!!!- Wont start
    I was sat on a garage forcourt waiting to fill up and turned the car off - left the key in the ignition.
    When the car in front moved on I turned the key to start the car and got absolutely nothing - dead. The lights on the dash came on as normal but when i turned the key to the III position nothing happened.
    upon investigation:
    1. The fuel pump primed
    2. The relays clicked with the turn of the key.
    I then checked
    3. Battery checked/fuses checked with multimeter all good.
    4. rocked car in gear to move the starter on
    Eventually pushed the car ot of the garage so i could tow it - thought id give it one last go and it started!!!!!!
    Drove home all good - started it it repeatedly at home all is fine.
    1 month ago the spanner popped on and put me in limp mode - and the blower has stopped in positions 123. notsure if there related but......
    Any ideas i would appreciate it.
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    the blower is your heater motor resistor check your scuttle tray isnt blocked and causing it to leak into the car
    May 2011
    North Yorks
    Yeh its blocked - got the resistor and new filter on its way - thats all sorted
    still have the spanner - not sure what the fault was as i have not had it read yet
    Thanks for the pointer
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    My neighbour had a problem with the key (immobiliser) - spare key started it.
    May 2011
    North Yorks
    tried both keys, neither worked - after it decided to start they both worked again. It did not show the immobiliser symbol on the dash
    Regular Member renodci's Avatar
    Kent
    Quote Originally Posted by Dal5band View Post
    That's what I was thinking - could be something as simple as a flat battery in the remote. Does the remote reliably lock/unlock the car using the plipper?
    It might even be that the imobiliser had activated - taking the key out of the ignition and locking then unlocking the car would probably resolve it - which might explain why it starts ok now. Might be worth trying that if it happens again.
    May 2011
    North Yorks
    tried all repeatedly - the car gets locked just fine with both keys - this happened for over an hour, nothing at all, i used he key in the door, it locked then unlocked as it should. finally just started!!!!..
    Very confused....
    May 2011
    North Yorks
    Update - used the car a few times today and it has behaved completely normal. Started on the turn of the Key. Should have mentioned its a 05 SRI CDTI 150 140k.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    also check the drain on the other side were the pollen filter is by the wiper linkage
    that gets blocked to
    i used a knitting needle to clear the drain
    May 2011
    North Yorks
    Over a week now and it has not reared its head - i would like to know if anybody has suffered similar and if there is an explanation?
  1. Vectra wont turn over
    By stevie b in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2012, 20:57
  2. please help vectra 2.2 dti wont turn over
    By deano1 in forum Engine & Drivetrain
    Last Post: 20th May 2011, 21:37
  3. HELP!! car wont turn over!!!
    By TimTay in forum Engine & Drivetrain
    Last Post: 31st March 2011, 19:08
  4. display wont turn off
    By Sauce in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 19:40
  5. Blowers wont turn off
    By KieronGSI in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2008, 08:21
vectra nothing when turn key
vectra turn key and nothing happens
corsa c turn key nothing
04 plate vectra c wont start off key n stereo stays on
turn key and nothing 2007 corsa
my vauxhall vectra wont start at all no
key wont start my vectra b
vauxhall vectra 54 plate wont start
