https:www.vectra-c.comforumshowthread.php178536-Rough-engine-start-1-9-CTDi
vectra sxi diesel rough idle at startup
opel vectra ctdi 1.9 starter,
1.9 cdti rough idle smoke cold start,
astra h running rough after bump start,
vectra c1.9 stuttering site:www.vectra-c.com,
https:www.vectra-c.comforumshowthread.php178536-Rough-engine-start-1-9-CTDipage3,
vauxhall astra 1.9 cdti rough running when started,
vectra c rough idle on startup then judder,
vectra c 150 cdti chugging on start up,
vectra c cold start rough idle,
vectra c 150 cdti chugging when starting up,
black smoke and rough idle at start Vauxhall vectra diesel,
1 9cdti cold start rough smoke leak off,
astra diesel running rough,
vauxhall 1.9cdti tappy when cold,
astra z19dth sounds rough when starting up,
vectra c rough idle cold start,
vectra c 1.9 cdti sri running lumpy,
z19dth rough starting,
astrs h 1.9 rough starting,
vauxhall vectra c chugging on start up,
https:www.vectra-c.comforumshowthread.php178536-Rough-engine-start-1-9-CTDi#::text=Check first all connections and connections also they can fail.&text=sounds like you got same get any whiteblack smoke,
https:www.vectra-c.comforumshowthread.php178536-Rough-engine-start-1-9-CTDipage8,
opel cdti after start rough
