Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 149
Thread: Rough engine start 1.9 CTDi
    Nov 2012
    EAST YORKSHIRE
    Default Rough engine start 1.9 CTDi
    Hi all,
    Recently got a 1.9CDTi which starts rough on the first start up of the day. After that, if starts fine.
    On the first start-up it fires up after a couple of seconds, then once started, it is very shakey and the engine sounds like its not running on all cylinders. After 10-15 seconds, it runs as it should.
    After doing my research it looks like it could be the leak off pipes?
    If so, are the pipes easy enough to replace? Tried looking for a how 2 on here but I can't find one.
    Does anyone else have any ideas what it could be?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Maybe glowplugs?
    Mar 2012
    york
    Sounds like it might be
    Nov 2012
    EAST YORKSHIRE
    Cars just had a full service, so I would of thought that would of been checked? On start-up the glow plug light comes on then turns off after a couple of seconds.
    Aug 2010
    Derbyshire
    Any warning light (for glowplugs) that stay on after start up? Usually they do if detecting 1 or more faulty plug.
    If it's the 150 engine they are easy enough to do and £40 should get you a decent set. If the engine is on high miles you will most likely need them changing anyway, if not been done recently.
    Check first all connections and that goes for injector connections also, they can fail.
    Mick
    Regular Member baines23's Avatar
    Oct 2012
    Dudley
    Vehicle : 2004 sxi
    Engine : 1.8
    sounds like you got same problem i did, mine turned out to be starter motor, mine took around 15 seconds to start till it fired up , and rest of day was fine like any other car starting up , do you get any white/black smoke?
    Nov 2010
    East Midlands
    Trim : design
    If you have one or even two glowplugs out of action at start up it will effectively only be running on two or three cylinders for a few seconds when starting from cold
    Nov 2012
    EAST YORKSHIRE
    Thanks for all your replies. Engine only takes a couple of seconds to start. Then after that it shudders for 10 seconds or so then ticks over as normal. Baines - I do get white smoke on a cold morning ( quite a lot sometimes) which goes once the engine has settled.
    This problem doesn't seem to be as bad when we have drove the car late the previous night I.e. less time sat turned off.
    Nov 2012
    EAST YORKSHIRE
    Oh and no glow plugs warning.
    Regular Member Boobi shabang's Avatar
    Dec 2012
    Wrexham
    Vehicle : Signum 1.9 CDTI
    Trim : DESIGN
    Engine : 150 BHP
    Mileage : 96,000
    This is exactly the same issue I'm seeing on my 1.9 cdti Siggy I purchased before Xmas, thought it could also be down to a weak battery as I left a interior light on overnight by accident and was greeted by a flat battery on Xmas day Taking it back to the garage Friday to take a look at another issue so i'll get them to check the glow plugs while I'm there, sounds rough first thing then fine starting later in the day, not really had a cold spell since I purchased to fully test it in the morning
  1. 2.2 Direct Rough Engine Noise on start up
    By Jonnie C in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 19:04
  2. Cdti rough running on cold start up
    By brimfull in forum Engine & Drivetrain
    Last Post: 19th January 2012, 20:16
  3. Help engine is rough
    By ONEMINUTESILENCE in forum Engine & Drivetrain
    Last Post: 28th December 2011, 14:09
  4. sri 150 running rough on start up help?
    By danni_kitch in forum Diesel Engine related
    Last Post: 26th September 2011, 13:30
  5. Engine rough as a badgers ar5
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2006, 07:22
vectra sxi diesel rough idle at startup
opel vectra ctdi 1.9 starter
1.9 cdti rough idle smoke cold start
astra h running rough after bump start
vauxhall astra 1.9 cdti rough running when started
https:www.vectra-c.comforumshowthread.php178536-Rough-engine-start-1-9-CTDipage3
vectra c 1.9 cdti sri running lumpy
z19dth rough starting
vectra c rough idle on startup then judder
1 9cdti cold start rough smoke leak off
z19dth 1 tooth out corse lumpy running
vauxhall vivaro 2013 rough idle on startup
vauxhall 1.9 cdti smoke and rough idle on start up
vauxhall 1.9 cdti rough idle on startup
vauxhall astra 1.9 cdti smoke on startup
vauxhall zafira cdti 120 rough idle
vectra c rough idle cold start
astra z19dth sounds rough when starting up
vectra c 1.9 cdti slight engine chugging
vectra c lumpy on cold start
vectra c cold start juddering site:www.vectra-c.com
vauxhall 1.9 rattle when cold
vectra c3.2 starts rough first crank then fine
vauxhall vectra c chugging on start up
astrs h 1.9 rough starting
