Thread: fuel gauge not working F miles ?
    Jan 2013
    Birmingham
    confused fuel gauge not working F miles ?
    fuel gauge not working at all and F miles on display ?
    fitted new sender ,fuse 17 is fine ,tryed the abs unplug trick and tested the wires going into the sender unit in the tank with it reading nothing at all ? no power ? , iv had a look at the plug under the tank and there are no brakes in the wires there ???
    any iders what to try next ?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    For opcom/ tech 2?
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    150 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Hmm, I've only seen those symptoms while programming the ECU with new mappings.
    I assume your car still starts and runs? If so then it must be some sort of can-bus fault stopping communication between the main ECU and the entertainment and instrument units. Like Chritch says, uou need opcom to work this one out..
    Jan 2013
    Birmingham
    Opcom any one have one that can help me out Birmingham area ?
    woodbridge, suffolk
    150 Post(s)
    Trim : Design+
    Mileage : 101000
    hmm, was out that way for new year and had opcom with me! Shame this hadn't happened a couple of days ago!
  1. fuel gauge stopped working - any idea's
    By Top banana in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2013, 09:48
  2. Fuel Gauge not working
    By m2yuout in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2013, 00:59
  3. fuel and temp gauge not working
    By hovis007 in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 19:35
  4. fuel gauge not working signum
    By superjetandy in forum Vectra C / Signum Troubleshooting
    Last Post: 28th February 2011, 15:45
  5. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
F miles vectra
f miles vectra c
signum fuel gauge fuse
vauxhall zafira display showing f miles
Vauxhall zafira f miles
vauxhall zafira f miles on display
