Thread: Fault codes
    Regular Member conman's Avatar
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Default Fault codes
    Hey guys, not the most technical minded and need a bit of help with the meaning of these fault codes if some kind soul could interpret them.
    I have a "Check Safeguard" warning for a while now and was wondering if one of these codes have something to do with it. I had checked internal sensors by not activating them and made no difference plus the alarm works fine and not going of randomly etc. Also if I don't lock the car and don't activate the alarm the "Check Safeguard" warning still comes up every time I put in the key and turn the ignition on. Just for reference I have a 2002 Vectra C 2.2 DTI 16v and the head unit is removed as I use my own stereo.
    Here's the codes I'm getting:
    U2105-71 CAN-Bus ECM Message Range/Performance (This one keeps coming back after code cleared)
    B3916-0F No Communication With Alarm Siren
    B3596-00 Invalid Trouble Code Please Ignore!
    B1375-00 Switched System Voltage (Ignition ON) Circuit Malfunction
    B3974-05 Driver Door Select Switch Window Lifter Circuit Open or High Voltage (Present)
    B1325-03 System Voltage Low Voltage
    U1420-04 Radio Bus Communication SDA open (Present)
    U1421-04 Radio Bus Communication SCL open (Present)
    U1422-04 Radio Bus Communication MRQ open (Present)
    B3608-06 <Unknown DTC>
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    Most likely the culprit, as per here:
    http://www.vectra-c.com/forum/showth...light=B3916-0F
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Cheers mate, will check the fuses and the battery backup in the sounder and see if I discover anything. Any ideas what the other codes are or would these all be because of the "Check Safeguard" error?
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    I went out and took a photo, I checked all the fuses and they were all ok. Can anyone tell me if this looks right? Seems like there are a load of fuses missing.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    there will be fuses missing as different models have different equipment , so have fuses in different slots .
    Sep 2012
    Saltburn-by-the-Sea
    Year : 55
    Mileage : 126000
    ...and...
    The top one is likely due to the missing original head (They have the ignition On/Off setting)
    The bottom three deffo are.
    From odb-codes.com:
    U2105:
    When the ECM stops communicating, the SOH that is normally sent every 2 seconds, disappears. The module that should receive that message detects the absence of the message and in turn sets DTC U2105.
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Quote Originally Posted by fistymus View Post
    From odb-codes.com:
    U2105:
    So don't this just mean a communication error between the ECU and the interface or something more serious?
    Sep 2012
    Saltburn-by-the-Sea
    Year : 55
    Mileage : 126000
    Could be a bad connection... Time for switch cleaner methinks
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    I think you might be right mate, I know I have some somewhere
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
Opel DTC B3F04-00
Vauxhall DTC B3f04-00
Vauxhall B1375-C
OPEL B1375-C
b1375 opel
b3596 fault code
vectra c b1375
vectra c low voltage fault codes
Opel DTC U2105-00
opel vectra c code b3608
B3608 opel vectra c
vectra alarm error codes
b1375 code on a vectra 1.9cdti
opel vectra c b3596
Vauxhall DTC B1375-5A
vauxhall code b3916
opel b1375c switched systems
Vauxhall DTC B1375-04
b3596 vectra c
vauxhall fault code b1375
Opel DTC U2105-71
opel vectra c b3608 error
Opel DTC B3596-5A
Opel DTC B1375-5A
u2105 vauxhall fault code
