Results 1 to 10 of 19
Thread: Sport switch?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Default Sport switch?
    Does the sport switch on a cdti increase power? What does it actually do?
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Which sport switch is that then?
    Do you mean the traction control switch you get on the 3.0 V6?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Guy on V sport has posted a thread about his sports switch on his sri xp estate. He was asking if when he used it would his mpg go down as it has more power. I thought all it did was alter suspension, steering, ESP and maybe auto box.
    You meaning on the 3.0? - wasn't aware of it being an option on a 1.9?
    On the 3.0 all I'm aware of it doing is what you said, nothing in the engine other than sharpening up the throttle response but no extra power/remap thing.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Must be a 1.9 as xp is not available on 3.0.
    Wilts
    Just had a look in the facelift brochure:
    Its IDS-plus and available as a cost option
    Note 7 says: Not available in conjuction with 1.8i 16v or 1.9CTi (120PS) engines
    Wilts
    Oh and the sport switch:
    Interactive Driving System-plus (IDS-plus) with Continuous
    Damping Control (CDC)
    D5. The Interactive Driving System (IDS-plus) chassis offers the
    driver an even more sporting driving experience, thanks mainly to the
    electronic control of the suspension. Pressing the Sport switch activates
    the CDC function – CDC monitors the roll, pitch and yaw of the car, and
    changes the rate of damping on each wheel to optimise the handling,
    effectively stiffening the suspension – but selectively. This means the
    vehicle will exhibit a reduced rate of roll and pitch, making it more
    responsive during direction changes and more settled during the
    braking/turn-in/acceleration transition when cornering. CDC is a
    major breakthrough in the segment.
    Sport switch
    D5. The functions of the Sport switch aren't limited to suspension
    control. When activated, it also affects the steering and accelerator
    pedal. The drive by wire throttle is altered electronically, leading to
    a sharper engine response and crisper acceleration, while the map
    of the power assisted steering is also adjusted, giving the driver a
    more positive initial turn-in on corner-entry.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Cheers for that, Ive copy and paste.
    Regular Member cameraman's Avatar
    Leicester
    I've got the IDS system (with sport switch) & ESP (with traction control switch) fitted to my 1.9CDTi 150 as optional extras, does make a noticable difference. The accelerator responce is sooo much better & the ride stiffens, average mpg doesn't appear to be noticibly affected tho.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Beauty of the sport switch is when you get it remapped you can have 2 different maps programmed onto it
  1. Sport Switch / ESP
    By Vec_elite in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2011, 13:29
  2. Sport switch
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2011, 23:46
  3. Sport switch
    Last Post: 21st March 2010, 23:09
  4. Sport switch again (sorry)
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2009, 14:38
