Thread: Rear wheel getting warm caliper sticking?
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Default Rear wheel getting warm caliper sticking?
    Took mine off yesterday as I noticed they were getting warm I cleaned up the caliper mounts and pads even wound the piston back in to check that, all seems to be working ok and spins free but the rear I/s wheel still gets warm compared to the n/s
    any ideas to check next I fitted all new discs n pads at 50 k cats only done 60 k now but has been stood around alot
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Did you check the slides were moving freely in the rubber slide mounts? Ive had this problem in the past and you need to take the rubber slide mounts out of the caliper and with some rolled up sand paper(or something like a Dremel) clean the corrosion out from where the mounts sit.
    Mar 2011
    llandrindod wells
    I did mate they were still clean n greased up from last time I did them
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Have you checked that the handbrake cables are running free and that the handbrake operating arms and springs on the caliper are moving freely.
    Oct 2012
    coventry
    I could be the wheel bearing as I had the same problem on my vectra B replaced the rear hub no more hot wheel
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    On mine, the spring on the Caliper that helps to release the hand brake had corroded to the point of nearly snapping. It was causing the rear brake to drag a little. I don't know if it was heating up because I only noticed the rear disc was all scored with chunks coming out. A pest because there not that old. Disc still does its job but doesn't look pretty compared to the rest. Check the condition of the spring while your there.
    Mar 2011
    llandrindod wells
    Cheers guys will drop wheel IFC and have another look at the w/e
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by slap204 View Post
    Could be - but I would have thought that he would be getting some noise- ie rumbling - if the bearing was badly worn.
    scotland
    slightly warped disc ? can happen when you sit with your foot on the brake at lights etc .
    Nov 2012
    cumbernauld
    pop the hand brake cable off the calliper and check if the cable is free or jammed. Next take the caliper off and opperate the hand brake cable with your hand is easy enough to do. If its overly stiff some wd40 and give it a couple of pumps with your hand. I would also bleed that caliper cause the fulid has probably boiled get some fresh stuff in and see how you go heat will just make it expand too much if its been cooked over could be causeing the piston to come out too much when its hot
  1. sticking caliper
    By skip85 in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2014, 12:49
  2. rear pads sticking on??
    By nickp1975 in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2013, 07:28
  3. 1.9 CDTi rear caliper sticking
    By Tennants in forum Suspension, Wheels & Brakes
    Last Post: 14th October 2012, 13:06
  4. rear brakes sticking
    By eminemme42 in forum Suspension, Wheels & Brakes
    Last Post: 13th March 2012, 21:20
  5. Rear Caliper \ wheel bearing
    By dmcl in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2007, 22:23
vectra c rear brake caliper sticking
insignia rear caliper sticking
rear wheek gets warm not brake caliper
rear wheel getting hot
insignia rear brakes sticking
vectra sticking brake caliper
front brake caliper sticking when it gets warm on a vauxhall vectra c cdti
vauxhall insignia brakes sticking
rear brake caliper stuck in opel vectra b
heat generated from hub vectra c
vectra c rear caliper sticking
Vectra 2005 rear brake sticking wheel hot
vauxhall antara rear brake sticking
vectra rear wheel bearing
vauxhall antara rear wheel sticking
rear wheel hot vectra c
wheel getting warm
rear pads sticking insignia
vauxhall insignia rear wheel heating up
Vectra rear brake caliper sticking wheel hot
insignia brake pistons sticking
vectra rear wheel warm
vauxhall vectra c sticking caliper
back brake sticking vauxhall signum
vectra rear wheel sticking
