Results 1 to 10 of 11
Thread: wheel controls full canbus
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    Default wheel controls full canbus
    When i turn the volume up on the scroll it turns down and when i scroll down turns the radio station took it off and cleaned it best i can and put it back on but hasnt worked any ideas some times it works sometimes it doesnt its doing me head in now
    cheers lads
    Dec 2011
    Seaham
    Sounds like the wires have been crossed or it has been mounted upseide down? Can you take the wheel out and mount it upside down?
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I has something similar when I change the leds on them.
    I had a tiny bit of solder creating a short and the scrolls did really wierd things. Removed the tiny bit of solder and they worked fine again.
    Don't know if this will help you or not but thought best to mention.
    Dec 2011
    liverpool
    6 Post(s)
    I havent done nothing on it its just been like this one day and the same well intermitent ever since
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Just out of interest what did you clean it with?
    Dec 2011
    liverpool
    6 Post(s)
    Just like pure alcohol evaporates in air on cotten woll bud just quick clean no debris left on contacts back together back on the car and nowt happened
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I'm going to sound odd, but try carb cleaner fluid..
    I used this on my passenger door switch contacts when they stopped working.
    It is most likely dirt or contamination on the little contacts withing the switches..
    A quick wipe with a cloth dampened with carb cleaner will sort it.
    Dec 2011
    liverpool
    6 Post(s)
    I have give it a clean though used pure alcohol its worked on other faulty switches so dont see y it hasnt with this one will give it ago mate cheers
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    many alcohols leave a white powdery residue when they dry fully, which will still affect the contact surface...
    Other than that, the switches themselves may be faulty, as it only takes a minor difference in resistance to provide a different switch function.
    I found this out when converting scroller switches to work my CD70 in my 1994 Cavalier (very long story - lol).
    Dec 2011
    liverpool
    6 Post(s)
    Ahhh your the fella woodpecks been speaking to about doing his cd70 arent you am the one helping him get all the bits from the car here your abit of a pro on the old cd70
  1. Full CanBus Steering Wheel and Headunit ID
    By Handyandy-UK in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2012, 10:39
  2. Steering controls in silver full canbus pre facelift
    By merikiito in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th October 2008, 10:48
  3. Full canbus steering wheel adapter
    By craigmerry in forum Parts for sale
    Last Post: 17th April 2008, 09:29
