Results 1 to 10 of 21
Thread: 54 plate vectra 2.0 DTI engine management light on
    Dec 2012
    scunthorpe
    StatsVehicle Info
    Default 54 plate vectra 2.0 DTI engine management light on
    hi all,
    my vectra 54plate 2.0 DTI engine management light on all the time runs like a bag of spanners smokes like mad when you put you foot down and is well down on power,
    Took it to garage they said fault was air flow metering unit but they tested it and said was ok re-set the light all was good then light on again. anyone got any ideas where to start?
    StatsVehicle Info
    The first thing i would do is check the vacuum pipework for splits and cracks. They are renowned for perishing over the years. Also check all your boost/inter-cooler pipework.
    When checking the boost pipe/inter-cooler pipework get someone to rev the engine while you take a look. You will see the pipework expand. It will give you a good chance to feel for or see/hear the splits if there are any present. When checking the vacuum pipe work pay particular attention to the rubber elbows and joints. these perish and split/crack. The one that fits onto the turbo actuator takes a lot of heat so can become very brittle.
    Dec 2012
    scunthorpe
    StatsVehicle Info
    cheers steve gunna have a good look over it i checked intercooler pipe work a while back all looks good was thinking of just changing all the vacum pipes & elbows see if that helps will i need to get the light re-set to make a differance or will it run ok if the vac pipes are the problem?
    StatsVehicle Info
    Once the vacuum has been restored the light should ho out.
    if its not inter-cooler or vac related my next step would be a strip and clean of the upper TB and the EGR valve. I would still check all the pipework thoroughly first. to rule things out step by step.
    which light have you showing? I assume its the car spanner?
    Dec 2012
    scunthorpe
    StatsVehicle Info
    no its the engine hazard bottom right in dash
    StatsVehicle Info
    You will need to get your codes read to pin point the problem
    Dec 2012
    scunthorpe
    StatsVehicle Info
    cheers steve gunna change out all vac pipe so rules that ok sick of paying garage £40 a time with no results
    StatsVehicle Info
    Yeah rule the simple stuff out first.
    There might be someone with a code reader in your area to read your codes hopefully.
    Chelmsford
    StatsVehicle Info
    Quote Originally Posted by danny 77 View Post
    Pick yourself up an ODB reader from ebay like this one...
    http://www.ebay.co.uk/itm/Car-Diagno...item416f736f3a
    Cost half as much as a trip to the garage...
    I picked up a rock bottom one a few years ago for about £15... Most basic thing in the world, but it's a god-send when it comes out to finding where the faults are...
    Regular Member wingi's Avatar
    Dec 2012
    clipstone
    StatsVehicle Info
    what p codes did the garage find? was the fault discription (mass air flow deviation)! if so it would appear you have the same fault as me on my 2.2 dti! no power (turbo no coming in) wont rev over 2500 prm eml on. near your battery there is a black rectangle box vacuum reservoir disconnect the pipe from it and you should hear a hissing sound if this is the case you do have vacuum! leave this disconnected and road test to see if turbo comes in and car drives ok.
  1. Vectra c engine management light
    By Mark Curran in forum Engine & Drivetrain
    Last Post: 16th May 2011, 11:39
  2. Vectra c engine management light on and no power
    Last Post: 13th May 2011, 15:28
  3. vectra 2.2 engine management light
    By jonahstfc in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2010, 15:46
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. Vectra B 2.2 SRI DTI Engine Management Light
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 10th January 2008, 19:08
eml on vauxhall vectra c 2.0 dti
eml on all the time vectra c
2004 vectra c 2.0 dti ecu light on
