Thread: Engine hesitating and generally lacking power
    Sep 2010
    Leyland
    Default Engine hesitating and generally lacking power
    My 1.8 VVT has just recently been lacking power and hesitating. I'm planting my foot to the metal but m speed decreases (motorway driving). Round town it's still evident but not to the same degree.
    I run on LPG (done about 25k so far) without any problems. The problem only seems to be happening when running on gas. If I switch to petrol, it goes away.
    The EML has come on and that's giving me 0301 - 0304 (all 4 cylinder misfires detected). Also a 0170 fuel correction dysfunction (assume its related to the misfiring).
    Im changing the LPG fuel filter and plugs tomorrow. Fingers will then be crossed to see if it works....if not, I assume it could be a coil pack failure...
    Any other suggestions?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Could be either for now. Gas needs a stronger spark than petrol so start with fresh plugs and gas filter then work from there. It's unusual for the coilpack to go and ALL cylinders misfire though so sounds like a fuel starvation problem.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Look at fuel trim. You'll more than likely find its down to fuel.
    a coil pack to break up on all four cylinders very uncommon
    Dec 2011
    Seaham
    When were the plugs last changed?? Also check the air filter and do the air box mod.
    Sep 2010
    Leyland
    I'd say plugs have been in for around 15-20k. I've done the air box mod and changed the air filter last week (only the OEM filter, not a K&N - someone needs to convince me I need to shell out that amount!).
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Sounds like a gas filter then. Have you ever changed it or is there any record of it being changed?
    Dec 2011
    Seaham
    Let us know how you get on after changing the plugs.
    Sep 2010
    Leyland
    Apparently the gas filters are only changed every two years, so march 2013 would have been its first change. I'll report back when ive changed both tomorrow.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    I would go with changing the plugs first
    Sent by nexus 7
    Sep 2010
    Leyland
    Plugs have been changed this morning. Was hoping to do the fuel filter at the same time but it ain't arrived yet. I'll road test on the way to work and see how it feels.
  1. 3.2 lacking in power.
    By Hyperhart in forum Engine & Drivetrain
    Last Post: 23rd July 2010, 13:19
  2. 3.2 v6 gsi lacking in power
    By arniuk in forum Engine & Drivetrain
    Last Post: 16th July 2010, 07:35
  3. lacking power
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2009, 21:47
  4. Vectra B engine problem hesitating
    By steve1975l in forum Engine & Drivetrain
    Last Post: 14th April 2009, 14:11
  5. engine light on,lacking acceleration,2nd and 5th gear manual mode
    By myvauxhall in forum Vectra C / Signum Troubleshooting
    Last Post: 7th April 2009, 10:58
