Thread: Pedal test won't work
    Regular Member johp778's Avatar
    Apr 2012
    Leeds, W Yorks
    Default Pedal test won't work
    Hi All, battery gone flat and wouldn't start car, managed to get enough charge in to start it now, but now spanner light coming up, but pedal test won't work, it's a 1.9 estate pre-facelift?
    I have recently been having the bulb out warning light coming on now & again, but I have no lights out, so not sure if this is something to do with the cause of battery drain, but I haven't had it running for 4 days & I have had some slight starting issues, so I should have just changed the battery when I did starter, but too late now
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Doesn't work on the 1.9's m8.
    Apr 2012
    Leeds, W Yorks
    Thanks, worked on brother-in-laws 1.9 Astra tho
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by johp778 View Post
    Not on the Vecs. There's alot you can do on the Astra and Corsa you can't do on the Vec/Sig.
    Apr 2012
    Leeds, W Yorks
    Typical Just got code read P0070 Ambient Air Temp Sens
  1. pedal test
    By GCusdin in forum Vectra C / Signum Troubleshooting
    Last Post: 1st February 2013, 12:07
  2. done pedal test and
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 26th March 2012, 22:07
  3. Pedal code Test
    By clowe7447 in forum Engine & Drivetrain
    Last Post: 13th September 2011, 07:43
  4. brake pedal test do it work on 55 plates???
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 15:06
  5. Pedal test
    By yadziyad in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2009, 20:02
pedal test vectra c facelift
opel pedal test doesnt work
vectra c 02 pedal test
pedal test on signum facelift
pedal test vauxhall vectra
https:www.vectra-c.comforumshowthread.php178493-Pedal-test-won-t-work
vectra c pedal test
does the pedal test work on vectra c
astra pedal test
