Thread: Power steering issue.
    Regular Member frankieboy1's Avatar
    Nov 2012
    humberside
    Default Power steering issue.
    Hi guys,
    i have an issue with the power steering on my 03 plate vec c Sri when I turn right it's fine when I turn left its stiff like there's no power steering at all really hard to turn then after the car warms up 25 miles or so it's fine like nothing is wrong I have topped up the fluid (what a pain in the arse). It was full so it's not coz of the fluid. Am at a loss any help would be great.
    Thanks dave.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Maybe a fluid change?
    Full Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    9 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    Have you thought about bleeding it?
    Dec 2010
    dundee
    my brother had same problem with his Vectra seems to be a common fault I found his problem was down to the connection on the battery because has a straight 12v there should be a small sized box beside the battery containing one fuse this was slack on my brother causing it to work and not work tightened the two 10 ml nuts and is perfect now hope this helps some people from getting ripped of previous owner spent hundreds on new pump and fitting etc and still had the same problem
  1. power steering issue
    By Baldwin in forum Vectra C / Signum Troubleshooting
    Last Post: 26th October 2012, 21:58
  2. power steering issue
    By jamesworts in forum Suspension, Wheels & Brakes
    Last Post: 26th May 2011, 19:10
  3. Power steering issue
    By MIAMI in forum Vectra C / Signum Troubleshooting
    Last Post: 21st September 2010, 21:05
  4. power steering issue
    By myelite150 in forum Engine & Drivetrain
    Last Post: 8th September 2010, 14:54
  5. Another Power Steering Issue 2.2 DTI Sri
    By l33byt in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2008, 13:20
