Results 1 to 10 of 23
Thread: Code 0300 & 0302 on 2.8 Signum elite
    Mar 2011
    Kent
    confused Code 0300 & 0302 on 2.8 Signum elite
    I had the engine running for about 30 mins, before I pulled out onto a motorway. The car went mental, it started to judder like mad, the EML light came on and it felt like I was running on square wheels !
    I could only get up to 60 and that was tough going as the engine sounded knackered and the car was very jerky. Fuel consumption went down to about 7 - 10 mpg in 4th 3rd and 2nd. 1st gear showed 1mpg for a second or two. Temp gauge which is usually on 90 - 92 held steady on 85 immediateley the EML came on. I nursed it home and plugged in my obd reader which threw up these two codes 0300 & 0302. I erased them and went for a test drive. The car was still a bit juddery but it feels like Ive lost the turbo. If I try to floor it the EML flashes and the car just simply judders, so I wont be doing that again but the fuel consumption figures are back to near normal. After about 2 miles the EML comes back on and the fuel consumption drops again and the juddering is as bad as ever.
    Is it worth noting that I always run on 99 RON fuel (V power/Tesco99) but 2 days ago I filled up with Esso 97 RON, would that affect the car ??
    Could it be a coil pack ? or a duff plug ? I was thinking of swapping 2 coil packs over and see what happens. Is it worth noting its running a superchips remap which has given me no trouble whatsoever in the two years Ive had the car.
    I did have a simlilar thing happen to a Zafira I onced owned, turned out to be the ECU was faulty.
    Any ideas anyone ?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    i would go with plugs first because they are cheap followed by a coilpack
    do you know any one you could swap and test the coilpack
    Mar 2011
    Kent
    I was thinking of swapping the coil packs over (if I can, Ive never done it before) and if I still get the code for the same cylinder then it cant be the coil pack thats faulty, I'll then swap a plug over and check again. After that I'm stumped really.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    ive seen on here juddering down to plugs and coilpack good luck mate
    Nov 2010
    East Midlands
    Trim : design
    0300 is a misfire or erratic misfires and 0302 indicates the problem is with plug/cylinder no 2 - I would be having a look at no 2 plug first off
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Pull plugs out and have a look. Put plug in coil an see if its firing
    Mar 2011
    Kent
    Will do. I wont do it tomorrow 'cos tomorrow I'm gonna be a bit hazy 'n' lazy (if you know what I mean)
    Happy new year guys...
    Full Member gixerjd's Avatar
    Dec 2011
    leeds
    Vehicle : vectra c
    Trim : vxr
    Engine : z28neh
    Mileage : 31000
    switch no 2 coil pack with another one say like 4 and see if the code changes will more than likely be the coil pack altho it could be a plug with it having multiple miss fire but i doubt it
    also coil packs for the 2.8 aint cheap £100+ and then + vat at the dealers each there is others on ebay cheaper around 70 quid each also worth checking the part code with a local motor factor see if they can get you one cheaper
    the revised coil pack part number for the 2.8 turbo is 12629037
    also the plugs aint cheap i think all the 2.8's and 2.8 turbos are fitted with the iridium type gm plug pn 55564748 and retail at £11.55 per plug + vat unless you have trade club then there £6.84 per plug plus vat
    also no the fuel wont make a difference unless there is something wrong at the station you filled up at eg they dropped diesel in the petrol tanks underground
    Regular Member wingi's Avatar
    Dec 2012
    clipstone
    with only p0302 cylinder misfire number two i would not think this was a fuel issue as i would expect other cylinders to misfire. if you can get hold of a coil on plug tester this will show if the coil is failing if not i would move the coil from 2 to 1 and vice versa if your misfire code moves with it it is the coil.
    Mar 2011
    Kent
    Before I start, which one is no.2 ???
  1. Off to look at a Signum Elite. Elite + suspension = GSI?
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2012, 10:42
  2. 0302 - cylinder 2 misfire detected
    By kristian in forum Engine & Drivetrain
    Last Post: 26th September 2011, 19:28
  3. Code 0302
    By BigWilko in forum Engine & Drivetrain
    Last Post: 26th May 2011, 22:15
  4. Faults 0300,0301,0303,0305
    By johnnylegs in forum Vectra C / Signum Troubleshooting
    Last Post: 26th March 2011, 23:56
  5. Got my 2.8T Elite Signum!
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 17:42
opel vectra 2.8 v6 p0302 code
0300 code read on vectra
