Hi all,ive recieved my new stat and housing today,im going to change it tomorrow on my 1.8vvt,the thing is the coolant is only 3 month old so whats the best way to do it without loosing too much of the coolant?
cheers
nick
cheers
nick
Leave the lid on the coolant bottle.
use a rag an pair of mole grips on rad hose.
undo and replace stat
refit hose remove clamp.
undo coolant lid. Run up and top up as necessary. pump rad hose to help remove air locks
should loose less than 1l doing it that.
hi which rad hose do i clamp,and you say refit hose and remove clamp?
cheers
Or just drain off the coolant into a clean bucket, via the hose from the thermostat housing.
The hose going to thermostat. I meant remove clamp as in mole grips sorry.
or as above drain system into clean bucket and refill
hi the hose going to the thermostat is one big one on the 1.8vvt, what about the coolant in the block
Refill with Evans Coolant... Be a Guinea Pig for the rest of us...!
Once you release the coolant tank cap, then the top hose, the coolant will find its own level through the rad. On the z18xer the other hose goes direct to the water pump, the bypass hose should allow the coolant in the head to drain out into the radiator. You shouldn't lose very much, if any coolant, when you remove the stat.
cheers guys so its just a case of removing the top hose that connects to the stat and draining into a container then that should should empty the block enough?
thanks
job done today instead,just drained the coolant from the hose connecting to the stat housing,lost some, but caught 4 litres maybe lost about 1 ltr, issue i have now is i filled the header tank to the usual place and still had 2 ltrs left to put in, ran the car upto temp then there were a few clangs etc and the level dropped in the expansion tank, at this minute its about 1 inch below normal level, but when i run the car the temp gets upto 97 deg,and the tank fills back up with coolant then overflows, the fans arent kicking in and the heaters are blowing cold,ive left it for 30 mins or so running to get all the air out,im leaving it overnight to settle and will run it back upto temp tomorrow,but does it just sound like an airlock somewhere?
cheers
nick
