Thread: Injector blue clips
    Oct 2012
    South Wales
    Default Injector blue clips
    Was having a clean about yesterday, took off the throttle housing and cleaned all that up, and it ****** needed it! also cleaned up the vanes around where the egr flow is meant to go.. again, so gunked up it took ages to clean all that out!
    Thought I'd pop off the electrical connectors for the injectors and check for any corrosion on the connectors... tried to pry out the blue plastic tab... snapped with minimal force applied... ******! two others came off fine, and then a second one snapped with hardly any pressure.. plastic had gone very brittle.
    Are the blue plastic tabs available to buy seperate at all from vauxhall? Or am I better off going to a scrappy ?
    Cheers.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Scrappy as far as I know but I may be wrong. Be inventive with a cable tie and it should hold the plug on until you can sort it.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    You need to open them up with a pick from inside, the tab does break very easily.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    The wiring kit from VX includes the blue plug (about £14) not sure if the clip itself can be swapped over though.
  1. Replies: 7
    Last Post: 2nd July 2012, 21:09
  2. renewing injector wiring clips.
    By cranny 27 in forum Engine & Drivetrain
    Last Post: 10th October 2009, 12:24
