Thread: P0400-f8 fault code
    Dec 2012
    N. Ireland
    Default P0400-f8 fault code
    Hi guys have a vectra 04 2.0dti that has brought up this fault code. Have cleaned the egr valve and checked all vacum pipes as other threads suggest. Any other checks I should do before I buy an egr valve.
    Thanks Lee
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    What about your boost pipes, the big black ones. prone to splitting .
    Dec 2012
    N. Ireland
    Have checked all pipe work including turbo to intercooler and boost pipes. When the fault isnt there it drives great
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Do you loose power when this fault occurs?
    If so then its a good chance you do have a split in the boost pipes or vacuum pipes. It only needs to be a small split, as when you are putting the engine under load more boost is required, therefore forcing its way out the tiny split.
    You may have to take your boost pipes off, and bend them around to find the split.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    When checking the boost pipe/inter-cooler pipe work get someone to rev the engine while you take a look. You will see the pipe work expand. It will give you a good chance to feel for or see/hear the splits if there are any present. When checking the vacuum pipe work pay particular attention to the rubber elbows and joints. these perish and split/crack. The one that fits onto the turbo actuator takes a lot of heat so can become very brittle.
    Dec 2012
    N. Ireland
    Cleaned egr valve yesterday and checked all pipework. Went like a pig everytime I tried it. Took it to work today and no issue then give it a good test on way home seems to be better than before. Fingers crossed will keep you posted. Gonna clean inlet manifold and boost sensor when I get a chance along with full service.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Have you insured the cable to the egr is connected properly , or is not stretch .
    another member on here recently had a problem of p0400 fault code coming up even though he had just fitted a new egr , it turned out that he had twisted the wire feed and caused it to be under tension.
    under advisement he reseated cable and fault dissapeared
    just a thought , but worth a try
    and still loving it
  1. Keep getting trouble code: P0400-5A, on SRI CDTI 150
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 18th January 2013, 19:38
  2. p0400-5a fault code
    By swvectra in forum Engine & Drivetrain
    Last Post: 12th July 2011, 06:57
  3. P0400 Fault code help needed PLease.
    By Nick1 in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  4. Error code p0400, EGR help.
    By Rainbow6six in forum Engine & Drivetrain
    Last Post: 21st July 2010, 10:07
  5. Error code: P0400 - EGR
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 3rd January 2008, 17:20
P0400-f8
Opel DTC P0400-f8
p0400-f8 vectra c
opel P0400-F8
2.0dti split intercooler pipe p0400
vectra p0400-f8
p0400-f8 opel
vectra c fault code p400-f8
fault code po400
opel codigo averia p0400(f8)
p0400 f8
p0400-f8#spf=1
Vauxhall P0400
Vauxhall DTC P0400-F8
Opel P0400(F8)
Vauxhall DTC P0400-07
