Results 1 to 10 of 16
Thread: upgrade or stock inter cooler, on 197bhp DTH
    Regular Member Mopar Man's Avatar
    herts
    Default upgrade or stock inter cooler, on 197bhp DTH
    Advise please.
    I need to replace my inter cooler, as mine is bent and leaking.
    Are there benefits in fitting an after market one, or stick with the standard set up. The car is a 06 1.9dth with a remap. Thanks
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    I was always intent that the stock intercooler was more than ample for the needs of a 1.9cdti. However, after speaking to member Harvey Smith, a man GREATLY in the know (R.I.P.) and having everything explained to me it would appear that the stock intercoolers, although capable of working sufficiently in the 280bhp VXR (the intercoolers are the same throughout the range) they are in fact cheap rubbish and in the wrong place. His advice was always go for an FMIC
    herts
    Thanks Big Willco. Yes the VXR dosnt get as hot. Just wondered if there was any performance benefits, in fitting different?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Supposedly yes. He was telling me that the couple of degrees difference in air temp due to the placement would make a significant difference and also the flow rate of the stock IC's isn't great for the diesels. If you can find one or get one made to suit the engine it's going on then you'll see performance benefits if what he says is gospel.... which i believe it is/ was.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Just to add what wilko said is correct 100%
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    There's a first time for everything
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Lmao mat its only because u spoke to harvey and me fpmsl hahaha
    herts
    Thanks for convincing me, to upgrade. Has anybody replaced, with a modified one. Ifso can i have a link or dimensions and hoses, if needed.Thanks again.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Ebay it mate theres a local company to me who sells the full kits
  1. Front mont inter cooler
    By richy1974 in forum Engine & Drivetrain
    Last Post: 9th July 2012, 17:25
  2. Inter coolers
    By wayne10244 in forum Diesel Engine related
    Last Post: 22nd February 2012, 13:44
  3. From Stock To Now.
    By Vectra_C_Chris in forum Quick Photo Album
    Last Post: 6th December 2010, 05:07
  4. Cooler than stock spark plugs - anyone fitted them?
    By dae36 in forum Engine & Drivetrain
    Last Post: 22nd April 2010, 10:49
