Results 1 to 3 of 3
Thread: Rear Seat Bolster
    Edinburgh
    Engine : 1.9 CDTI 150
    Default Rear Seat Bolster
    Hi, I am having massive dramas removing my rear set bolsters. I have tugged and pulled them but to no avail, I have demolished one of the white plastic bits to remove one, but don't fancy doin this again. Is there any other way to do it ?
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    182 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Hi. If you are talking about demolishing the white plastic retaining clips, don't worry too much, the part number is 24437789 from Vx £8.50 each plus VAT or less 25% if your car is getting on, and you are registered with Vauxhall Members / Masterfit Club ie £6.38 each plus VAT.
    Anyway, back to removing the bolsters. When I helped out doing this there were 2 of us. My mate started the "pulling away" process so that the clips were exposed, then I clamped the clips (not agressively, more like a hard squeeze) with a mole wrench set to lock on the spring clip. Another final tug on the bolster, and they were out.
    No broken clips after that using this method.
    Hope this helps m8
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Removing the side bolsters can be a real pita. As the wire/frame is moulded into the bolster you run the risk of pulling the wire out of the moulding. What you need to do is feel where the wire is and then give it a few hard tugs (One hand on either side of the wire) It's one of those things that when you've done it once its a lot easier next time
  1. Driver's seat base side bolster....
    By John LE in forum Bodywork & Interior
    Last Post: 3rd April 2011, 23:21
  2. seat bases bolster repair ??
    By bembo449 in forum Bodywork & Interior
    Last Post: 10th February 2011, 00:49
  3. SRI Sports Seats Repair Bolster or Seat Covers
    By mxt in forum Bodywork & Interior
    Last Post: 19th December 2010, 15:09
  4. Rear seat bolster removal
    Last Post: 24th February 2010, 18:16
  5. Repairing seat side bolster
    By stuartbat in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2008, 01:43
How do I remove the back seat in my vectra gsi c
