Thread: Vecta Intake Manifold
    Regular Member dalekirkwood's Avatar
    Feb 2012
    Cambridge
    Default Vecta Intake Manifold
    Hi All.
    Got the Intake Manifold Problem come up. Do I need to change the servo as well or can I just change the manifold. I found a listing on ebay that says I need to change both.
    Dale
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    This suggests you ned to change them both:
    http://www.ms-motor-service.com/xima...93a_en_web.pdf
    Feb 2012
    Cambridge
    I have done a little research. I don't think you need to change if the acuator still works, but it is advised.
    Engine : 1.9 CDTi
    Depends whats causing the error code.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    if an error is coming up its usually because the servo cant move the swirl valves due to gunk buildup. As for changing the servo, its down to preference tbh. Ive done loads and never once changed it, had no complaints so far
  1. For Sale: Intake Manifold
    By neill in forum Parts for sale
    Last Post: 20th September 2012, 14:36
  2. Dreaded Intake Manifold
    By cooky516 in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2010, 12:12
  3. Intake manifold £££
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2009, 18:31
  4. intake manifold/swirl actuator
    By John-joe in forum Engine & Drivetrain
    Last Post: 13th August 2008, 14:09
  5. Intake Manifold Valve 1
    By Adamant in forum Engine & Drivetrain
    Last Post: 21st August 2007, 20:13
