Thread: water temp dial
    Regular Member IRMSCHER ALBA's Avatar
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    Default water temp dial
    can anyone please tell me which wire goes to the water temp dial
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Check the sender connection first, that's more than likely where you'll find the problem. What engine?
    Sent from my Nexus 7 using Forum Runner
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    theres not a prblem i am looking to connect an aftermarket dial up to the existing wire
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    engine is 1.8 petrol 2007 sri
    Vehicle : SRi
    Mileage : 137000
    You don't want to be messing with that, not on these cars, its not like the old type wiring. The same sender also passes info to the ecu for fueling and choke.
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    will i be able to run a wire from the new dial to the water temp sender
    Vehicle : SRi
    Mileage : 137000
    I wouldn't like to say mate, I'll let someone more qualified answer that one.
    Sent from my Tyrell Corp Nexus 6 using Forum Runner
  1. Water temp gauge
    By obews in forum Engine & Drivetrain
    Last Post: 6th August 2012, 19:07
  2. water temp gauge
    By vectra.sri in forum Engine & Drivetrain
    Last Post: 26th August 2011, 00:18
  3. preface 1.8 temp dial slow to get moving
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:50
  4. Temp dial not working/clicking behind dash?
    By Terry Tibbs in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 18:12
  5. 1.9cdti water temp
    By scotstrucker in forum Engine & Drivetrain
    Last Post: 26th December 2009, 16:43
which wire is the water temperature in vectra c
