Results 1 to 10 of 25
Thread: Aftermarket Stereo wiring question
    Nov 2012
    EAST YORKSHIRE
    Default Aftermarket Stereo wiring question
    Hi,
    Just had a go at connecting the new stereo, however there is no power getting to it. I am using the correct adaptor (i think).
    I think the problem is that there is not enough power getting to the stereo, so I have tried finding another 12v feed from the GM loom but theres nothing.
    I have read on other posts that other users have tapped into the cig lighter wire or the ignition feed. To be honest, I don't fancy doing that as I am not a competent person!
    The only way I have power to the stereo is to piggy back two wires in the same 12v feed from the GM loom.
    My question is; is this safe, or am I going to blow something up?
    Thanks in advance.
    Regular Member roverjay's Avatar
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    When you say no power have you tried swapping the permanent and ignition lives around or tried a multimeter on the plug to test for a live
    Nov 2012
    EAST YORKSHIRE
    Thanks for your reply.
    Do you know what the colour for these cables are from the GM loom? I dont have a multimeter so cant do that.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Red and yellow.
    Nov 2012
    EAST YORKSHIRE
    Tried this and it still didn't work. Is there any reason why I cannot solder both connections to go through the single 12v feed (red cable on the GM loom)
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    The adapter harness sometimes has bullet connections on the 2 lives so you can swap them around
    Nov 2012
    EAST YORKSHIRE
    Aye, well tried swapping them but it made no difference (obviously I made sure I had the ignition on!)
    I'm not to bothered about having to switch off/on the stereo myself, so would my solution in my last comment be okay? Oh are we looking at a major no-no.
    Thanks for all help so far.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Are you sure you have the right connector?
    what wires are you piggy backing?
    Nov 2012
    EAST YORKSHIRE
    Yeah i have the right connectors.
    Just want to know if i can connect (solder) the red and the yellow wires from the aftermarket stereo to the constant 12v supply (red wire) from the car.
    Nov 2012
    cumbernauld
    you could but it wouldnt be a good idea if you left the stereo on you would drain battery if its a permenant live and an ignition live would loose settings when the ignition is off. What year is your car ? I just fitted a sony to mine cause i had to charge the battery and didnt have the sereo code. All i needed to do was swap the yellow and red wires round the keep the radio settings. I have a 2005 vec c 1.8 ls
  1. which aftermarket stereo
    By a6lns in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:50
  2. Aftermarket stereo
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2010, 15:20
  3. What wiring connectors i need to fit aftermarket stereo and still have OBC
    By daftvectralad in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2008, 14:04
  4. aftermarket stereo
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2008, 22:26
  5. Wiring Question for Aftermarket Headunit??
    By Cilldara1 in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2007, 21:21
vauxhall vectra c stereo wiring to aftermarket stereo
vectra c aftermarket stereo
vectra c fit aftermarket radio
https:www.vectra-c.comforumshowthread.php178371-Aftermarket-Stereo-wiring-question
vectra aftermarket stereo
fitting aftermarket stereo vectra c
vectra c radio wiring diagram
wiring colours on a 08 vauxhall vectra radio
vectra c iso plug to big for aftermarket stereo
aftermarket stereos for vauxhall vectra cno power to my radio in vectrawhow do i keep memory on an aftermarket stereo vectra cno power to aftermarket stereo corsa cvectra c stereo no power to aftermarket stereohow to install aftermarket stereo to vectra cvectra new stereofit aftermarket head unit vectra cvectra stereo wiring diagramhow comes my new sterio works without a switchlive in a vectra cvectra c iso connectorvauxhall vectra c 2007 radio loomvauxhall vectra c radio wiring diagramhow to wire screen in vectra c to aftermarket stereovectra c radio wiringhow to fit aftermarket stero vectra c
