Results 1 to 10 of 15
Thread: Driver footwell wet
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    Default Driver footwell wet
    Noticed the other day that the drivers foowell has quite abit of water there. Looked on here and checked everything that people have said. Door and window seals, Drain by the pollen filter. Dried the carpet and came out the next day and it was wet through again.
    Anyone got anymore ideas to what it could be?
    Thanks in advance for your help.
    Mike
    Nov 2012
    Essex
    Leaking heater matrix?
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    How do I check the heater matrix? Sorry new to all of this. Normally take it to the garage but want to learn things for myself now.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    Quote Originally Posted by mikey2704 View Post
    Mike
    theres another drain by the wiper linkage
    if you look were the pollen filter drain is along to the left you will see another drain that will be blocked up
    this pours into the drivers footwell then
    i use a knitting needle to clear the drain to get through the grid
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Yes mate , the drivers side drain hole is a ***** to get too but it's probably blocked, mine was blocked solid,, I've now removed em both...
    Sent from my iPhone using Forum Runner
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    I have removed both drain rubbers now. What's the best way to dry out the carpet as its like a swimming pool. I haven't got a wet vac any ideas would be great.
    Thank you
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    I'm still getting water in the footwell. Any other ideas of what could be causing this? How do I check the heater matrix?
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    Could it be melted snow off your feet .
    Or is there too much water ?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Heater matrix is behind black cover next to foot rest at drivers footwell. Remove panel next to footrest. Black cover is held by 2/3 screws. If the black cover are wet then its heater matrix seal is lost. But most likely its just need tightening the fittings.
    Check ur weather strips. Close door. Have wife or girlfriend sit inside watch door as u pour water over door seals.
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    Are you loosing coolent?
    If not then forget about the heater matrix.
  1. wet footwell
    By kewley in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2011, 21:05
  2. Wet carpet in footwell
    By s1nglef1sh in forum Bodywork & Interior
    Last Post: 12th March 2009, 01:23
  3. Advanced driver courses.(Class A driver)
    By Craig1985 in forum General Chat
    Last Post: 19th August 2008, 10:48
  4. Water in driver footwell
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2006, 20:27
vectra driver footwell wet
