Thread: Vectra 1.9 16v starting problem
    Dec 2012
    manchester
    Default Vectra 1.9 16v starting problem
    Hi
    This his is my second post on the group and just looking for some advice.
    i have a 2005 Vectra c 1.9 16v which is causing me a headache in the morning, or first start of the day.
    its takes that long to start that I'm now having to jump start every first start of the day. Once warmed up it's okay.
    its been like this for a few months now and I can't afford to pay a mechanic to look at it. I do have a friend who put a fault reader on it and the only thing that came up was a glow device general error. I'm not a mechanic but as far as I'm aware the glow plugs only aid the start up for a second or 2, I would have thought by the time the battery had died that it would be warm enough.
    any help or suggestions would be appreciated.
    many thanks
    East Ayrshire
    Trim : SRI XP1
    Not quite, I'd be putting in new glow plugs. The glow plugs heat up the chamber to allow the engine to start, however if they aren't heating up at all then it can't start. They're not expensive so I'd go down that route first
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    Glow plugs are cheap enough, on the 16v there easy enough to diy.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    96 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    I second the recommendation of glow plug repalcement.
    Note: Get GM branded ones, or BERU (this is the manufacturer of the OE plugs). I first got some NGK branded ones and the Glow Device General Error code came back after being cleared.
    I found this to be because the resistance of the NGK plugs was different to the OE ones, and therefore the glow control unit thinks they are faulty.
    Dec 2012
    manchester
    Will give that a whirl guys, is it defo an easy DIY job? I've changed spark plugs on a 1.2 corsa if that counts
    East Ayrshire
    Trim : SRI XP1
    Not much different to it. Just make sure you take you're time when you're undoing them as they can seize in sometimes
    http://www.vectra-c.com/forum/showth...gs-on-1-9-CDTi
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    When you try to start from cold next time let the glowplug cycle run 2 or 3 times before trying to start the engine - ie turn the ignition key to the ignition setting and wait until the glowplug light goes out, but do not turn the starter motor over, turn off then repeat twice more before finally turning the engine over. It's unlikely that all four glow plugs will have failed and by doing this it will allow the working ones to get hotter and help start a cold engine. Also the glowplugs continue to operate even when the light has gone out - if you listen carefully you can hear the relay click off when done. There are a lot of old threads re cold start problems if you do a search.
    Have a look here for some ideas - http://www.vectra-c.com/forum/showth...=cold+starting
  1. Vectra C 2.0 Dti Starting Problem.
    By TheTakman in forum Engine & Drivetrain
    Last Post: 28th January 2013, 22:19
  2. Vectra C 2005 CDTi 1.9 8v - Starting Problem
    By aaronfenwick in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 12:44
  3. 2006 vectra 1.9cdti starting problem and i=oil leak on start up
    By tomstubbings in forum Engine & Drivetrain
    Last Post: 24th September 2011, 10:01
  4. vectra 04 cdti 120 starting problem
    By andyman201 in forum Engine & Drivetrain
    Last Post: 24th December 2009, 20:15
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
vectra cdti starting problems
