Thread: 2.0dti clutch master cylinder
    Mar 2011
    South Normanton, Debryshire
    Default 2.0dti clutch master cylinder
    Hi anyone know good places to order a clutch masterccylinder from I'm sure I'll need one can I order just any or does it actually have to be for my engine? What'sa good price iI'm looking for?
    Cheers Alan
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What makes you think you need a master cylinder?
    Mar 2011
    Thought clutch went yesterday tried putting more clutch fluid in it work then went to it this morning and clutch went straight to floor again so done a full flush today which again worked so going to check see if it still works tomorrowif not then going to sstartby cchanging the master cylinderwhich iI've been told is the cheaper option then the slave cylinder does this sound right or should we try something else first?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Try clamping pipe to the slave first if it goes hard then its the Slave.
    is it loosing fluid?
    Mar 2011
    No doesn't seem to be losing any fluid was just black so just flushedit all out to new clear fluid. Do you mean the clutch pedal will go hard? And where is the pipe to clamp? My friend normally does everything as I don'tknow aa lot about cars
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    If its going black its a good sign of master cylinder seals going.
    Yeah clutch pedal should go stiff.
    the flexi pipe on top of the box going to the nipple.
    Mar 2011
    Ok thanks for your help my mate thought it would more be the master cylinder. But at least can test the slave now as well. Also my mate wanted to know the answer to a question is the slave attached to the clutch so the clutch has to be replaced at the same time? Just a question just in case
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It's concentric slave so its inside the bell housing.so will need to fit box.
    its not physically fitted to clutch so in theory can change just slave. But with all work involved. It's false economy not to change clutch at same time
    Mar 2011
    Yeah we thought that if it goes that far ill be havingit all cchanged thanks for your help again
  1. master cylinder i think????
    By stickygreen in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2012, 18:43
  2. Clutch + DMF + master + slave cylinder
    By Bobsta in forum Engine & Drivetrain
    Last Post: 9th November 2012, 23:33
  3. master cylinder
    By SarahP in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2012, 15:15
  4. Anyone had to have a clutch master cylinder?
    By DaveW555 in forum Engine & Drivetrain
    Last Post: 13th April 2012, 22:56
  5. Vectra C Clutch / master Cylinder
    By k34sty in forum Engine & Drivetrain
    Last Post: 22nd March 2012, 09:19
vectra c 2.0 dti clutch
vectra clutch mater cylinder
what dpes my clucth pedal is on the floor in vectra c 2ldti
