Thread: alloy corrosion
    Oct 2010
    n.i
    Default alloy corrosion
    my car 2011 may insignia sri with 18 inch twin spooks has small rust like spots on 3 wheels.they are on the edge of the inner part of the wheel,where the wheel divides from inside to outside. should i get them replaced under warranty. the 4th wheel is being replaced by vauxhall because the lacuer has come off on one spot. is this common. what should i do. help please. its taken 7 months to get the first wheel replaced.
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Should not be getting that kind of reaction on a motor that age ...its only going to get worse i would be back at them
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    as above mate
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Definitely.
    Regular Member Craig1985's Avatar
    harwich essex
    Are you using a strong alloy cleaner? Or maybe the previous owner did and its burnt the lacquer?
    Oct 2010
    n.i
    i bought the car new,i only use car shampoo and water
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Same problem with the VXR 20" alloys (mine included).
    Some on VXRO have had some luck getting them changed under warrenty but it's taken them many months before they've agreed to replace them.
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    I believe aswell that the dealer drills a hole through the rim so they don't go "missing" when replaced.
  1. Subframe corrosion holes
    By helisurf in forum Bodywork & Interior
    Last Post: 3rd November 2011, 22:41
  2. Vxr centre caps corrosion
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 19:56
  3. Brake line corrosion
    By barry087 in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2010, 21:31
  4. Anti Corrosion Warranty
    By rorycarz in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2007, 20:28
  5. headlight corrosion
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2006, 15:05
