Thread: 1.8VVTi Z18XER - Spark Plugs
    Full Member
    Nov 2012
    Norway
    Default 1.8VVTi Z18XER - Spark Plugs
    I suppose the factory fitted "standard" spark plugs are rebranded Bosch, but I could be wrong here:
    Bosch FQR8LEU2 (0 242 229 699) with gap 0.9 mm
    The recommended NGK:
    NGK ZFR5F-11 (2262) with gap 1.1 mm
    and the iridium upgrade
    NGK ZFR5FIX-11 (2477)
    Does anyone have any experience with these. Heard someone mention that his engine kind of ran better on the standard NGK ones than on the iridium NGK ones.
    Dec 2011
    Seaham
    I just put in standard NGK plugs, car runs spot on. I can see no real benefit running iridium plugs as it is not a high performance engine.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    I have iridium plugs in mine they seem to perform very well and I believe they last far longer than conventional plugs,they were in it when I got it so I can't really compare it to anything as I've never had normal plugs in it
    Regular Member k9vnd's Avatar
    Dec 2012
    fife
    Vehicle : Vectra sri vvt
    Engine : 1.8 vvt
    Mileage : 74000
    Just fitted iridium one's last month, there is a slight but slightly better differance than the ngk plug's i had previous, mine's the 1.8 vvt too.
  1. 1.8vvti spark plug gap
    By Knight Rider in forum Petrol Engine related
    Last Post: 17th February 2011, 09:26
  2. spark plugs for 1.8vvti
    By rollinon19s in forum Petrol Engine related
    Last Post: 16th April 2010, 08:16
  3. Best spark plugs for a Z18XER?
    By Baz07 in forum Engine & Drivetrain
    Last Post: 7th January 2010, 01:23
  4. Spark Plugs on a Z18XER?
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2007, 09:03
z18xer spark plug gap
ngk plug gap for z18xer
z18xer spark plugs
vauxhall zafira b 1.8 spark plug specs
z18xer
spark plugs for z18xer
vauxhall insignia 1.8 iridium spark plugs
z18xer spark plug gap ngk
vauxhall insignia 1.8 spark plug gap
zfr5fix-11 vectra c
best spark plugs for sri 1.8
spark plug gap vectra iridium
z18xer spark plug torque
vectra z18xer iridium
VAUXHALL VECTRA PLUG GAP
ngk spark plug gap Z18XER VAUXHALL ENGIN
Vauxhall astra 2006 1.8 sri spark plug gap
vauxhall:zafira spark plug torqe
correct spark plug vectra c 1.8
1.8 vvti vauxhall engine spark plugs
best spark plug for z18xer
vauxhall z18xer spark plug gap
bosch spark plugs ok for vectra 1.vvti
vauxhall insignia 1.8 best spark plug
how to change spark plugs on opel z18xer engins
