Thread: Cdti 120 timing
    Oct 2012
    Ashford, Middlesex
    Default Cdti 120 timing
    Camshaft pulley timing mark is not lined up with the mark on the cam cover, should it be or not ??? Car is getting 58.8 mpg on a long run even though its about 6-7 teeth out on cam timing, I'm stumped, do I line it up or leave it ??? Could this be causing my bad idle and smoke on cold starts, please help
    Jun 2011
    wolverhampton
    If you were 6 teeth out buddy you wouldn't be running trust me.
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Are you sure your looking at correct markings? 6 teeth would be a lot of trouble I doubt you'd get down the drive never mind a run
    Jan 2012
    Dublin
    I used to make these engines for a living. If memory serves me right theres a mark on the crank pully that "looks" like a timing mark but isnt, and indeed theres a notch on the oil pump body which looks like it should be the mark to line it up. Neither of these are actually timing marks and when lined up will have the timing out by several teeth. Theres a proper kit for timing the crank and cam, you remove the bottom left oil pump bolt and insert a stud in its place, a timing tool then fits over the stud and matches up with the round protruding bit on the crank pully when cylinder 1 is at tdc. Lol thats the proper way but everyone just uses tip-ex to mark the crank's position when the cam is timed and then rip the belt off
    Oct 2012
    Ashford, Middlesex
    i've got a timing kit now so gonna use that and see how things go, i will take some pics this time.
    Oct 2012
    Ashford, Middlesex
    well all done, i stripped it all down again then used the timing marks on the new belt i had and all was good. (when i was at a vauxhall service department yesterday i got told there is never timing marks on the belts). the only rattle on the car is the dmf which will be done in the next few weeks, managed to get a gm kit for £480 trade price, not sure wether to try it myself or stick it in somewhere and pay for it to be done.
    Do egr valves have to be programmed or are they plug and play ???
    Engine : 1.9 CDTi
    Plug and play
    Oct 2012
    Ashford, Middlesex
    Yeah that's what I thought, got told yesterday at vauxhall they need programmed,
  1. where to get 19 cdti 150 timing belt kit?
    By ronnie63 in forum The 'Off Topic' room
    Last Post: 25th August 2012, 17:24
  2. 150 cdti timing belt again
    By dubsrus in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 09:33
  3. timing belt 1.9 cdti
    By fingers66 in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2010, 18:49
  4. cdti 150 timing belt kit, where's best to get it from?
    By veralum in forum Engine & Drivetrain
    Last Post: 19th January 2010, 18:32
  5. 3.0 Cdti Timing Belt Kit at least £250!!!!!
    By robster23 in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2009, 15:16
vectra c 1.9cdti 16v timing belt tool site:www.vectra-c.com
