Results 1 to 10 of 21
Thread: drls
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default drls
    i know a lot of people dont like drls, but for those who do, can anyone help.
    i have a preface and i want to put them next to the fogs in the recess. i gather from a bit of research i need 10cm ish units.
    looking on ebay is difficult as you cant see how bright they actually are. so what have people got, pics would be useful and any links. id love the phillips 4led ones but not for £60
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    138 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Hi, just wondering if you knew that you can probably have your programmed so that your foglamps become DRL's until you swtch on the main lamps, or use your foglamps actually as foglamps using the switch, otherwise they operate in a dimmed down manner as soon as you start your engine.
    As said, just a thought, having done this on my preface Gsi.
    Woody
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Did look. Want the white look though. The fogs wouldnt give that. Good idea though
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    can this be done to a facelift??
    May 2012
    138 Post(s)
    Mileage : 131,000
    Quote Originally Posted by rozzer2006 View Post
    Not sure if you mean programming foglamps ? If you do, then I'm sorry but as far as I know, it isn't an option on the facelift to use foglamps like that, only dipped beam or sidelights from what I recall.
    Woody
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    No. Only the half-can models can have the fogs programmed as DRL's
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    You mean in this recess where the Ali is?
    Think its up to 13/14cm wide. There's loads of 1cm x 10cm+ on eBay if prepared to wait from china, to be fair 4 or 6 LEDs the brightness is gonna be similar as LEDs, I wouldn't worry about that, just get ones that fit, and far enough back that the may look "standard"...
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Thats the spot im after
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by woodpeck View Post
    Woody
    Quote Originally Posted by andy_richmond View Post
    Its not an idea as such, but how the car came from the factory, just the same as how you can turn off DRL on Audi's at the dealer. The system is built in, and as Woody said, the fogs come on but dimmer with the engine, if you were to turn on your sidelights or headlights the DRL's deactivate and the fogs return to the stock factory setting and power output.
    A good set of bulbs also help with the colour. Think VW DRL's but not yellow. This is mine with DRL activated and Mtec bulbs fitted. Granted, the pics do make the light look ice white than in life but there not yellow but white.
    Note there are no sidelights on
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
  1. My HIDs and DRLs
    By antowens in forum Styling
    Last Post: 24th December 2012, 16:23
  2. drls which set to buy
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2012, 14:51
  3. Led drls
    By new boy in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2012, 12:33
  4. DRLs' nearly done
    By lizard in forum Styling
    Last Post: 28th March 2011, 21:53
  5. drls
    By topgun in forum Styling
    Last Post: 13th April 2010, 15:57
