Results 1 to 10 of 15
Thread: Sensor telling me back door is open?! but its not!
    Regular Member TAB's Avatar
    Nov 2012
    Forest Town, Mansfield, Notts
    Vehicle : Vectra C VXR
    Trim : VXR Fully Loaded
    Engine : 2.8 Turbo, remapped
    Mileage : 65,000
    Default Sensor telling me back door is open?! but its not!
    Hi folks
    Any ideas?
    Back offside/drivers side is telling me its open, when it isnt, ive tried opening closing door, locking/unlocking with key and interior button, had a look around the door itself, cant see anything obvious.
    Also, the interior lights are staying on, presumably because it thinks the door is open? Had to manually turn them off.
    Where is the sensor and is it easy to get to, or an easy fix?
    TYIA
    Regards
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Change the door lock for the door, as its not a seperate sensor.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    As above needs new door lock.
    as a temporary fix squirt some wd40 directly into mechanism and operate closed and open with screwdriver several times it may bring switch back into operation until after new year to give you chance to get a door lock.
    Nov 2012
    Mileage : 65,000
    Thanks.. Really?! Noooo ... thought it would be simpler than that? Squirt WD40 in to where exactly?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Into the lock mechanism (door open) but point it as of your try to squirt outside if that makes sense.
    then use screwdriver to press lock over and press it gently back. Operate handle do it several times and it may do the trick.
    The lock isn't as expensive as you may think. I got drivers door lock from car part connection 26 quid to the door.
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    Also had issues on a vectra with the wiring going through the door to the B post.
    Worth checking.
    Nov 2012
    Mileage : 65,000
    Tried the above, and removing fuses to see if it reset, but no....new lock then?!
    Nov 2012
    Mileage : 65,000
    Just had a look at 'how to', this shows drivers door though, central locking etc etc, so is it the same for rear doors too?!! please tell me its not...looks a right ball-ache!
    Engine : 2.2 Direct
    It is ;-)
    Nov 2012
    Mileage : 65,000
    Noooooooooo .. right.. tomorrows job then
  1. Replies: 32
    Last Post: 2nd January 2013, 02:18
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  4. p0335 crankshaft sensor open circuit
    By jon1.9cdti in forum Engine & Drivetrain
    Last Post: 28th July 2010, 11:52
  5. Boot Open Sensor/Indicator
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2008, 23:25
vxr second oxygen sensor open circuit
