Thread: CD70 (satnav model) not coming on with ignition
    Cambridge
    Engine : 3.0 V6 CDTI
    Default CD70 (satnav model) not coming on with ignition
    Hi guys I have the above in my 94 f/l vectra and for some reason it currently isn't coming on with the ignition. Infact on startup it's completely unresponsive and appears dead and only after driving for roughly 20mins or so does it spark in to life and work, it's done this three time in the last three days after the car had been sat for a few days, I have no other electrical issues and the car is starting fine.
    Any ideas????
    Thanks in advance.
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    There is a setting on the menus for "turn on with ignition". Could be this. Worth a try. Strange that it comes on after a while. Could be worth taking the radio out and checking the wiring.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Cambridge
    The setting for the ignition on hasn't been changed and has always been set to ignition logic on. Thing is I can't even turn it on, the buttons on the front are inactive and I can't even clear the screen of the usual plethora of annoying warnings about screen wash etc unless I use the steering wheel controls.
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    sounds like a loose cable on the back of the head unit m8
    Dec 2011
    Seaham
    Pull the unit out check the power and earth connections, sounds like a loose or poor connection.
    Cambridge
    How does one get it out? And would a loose connection explain the fact that it comes on after a while of driving?!
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    get a set of pins for taking it out at your local motorstore mate ,push them in then squeeze towards each other and pull thats the way i usually take them out , it may well be that the poor connection(if that is what it is ) is just a dirty or corroded contact a little spray with electrical cleaner should sort it HTH
  1. Cd70 satnav
    By stanlee in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2012, 19:12
  2. Replies: 3
    Last Post: 5th January 2012, 19:15
  3. Replies: 2
    Last Post: 11th June 2011, 11:29
  4. My CD70 won't turn on and off with ignition anymore?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 13:07
  5. 2005 vectra sri cdti 120 satnav model
    By Turbomanrony in forum Cars for sale
    Last Post: 2nd October 2010, 17:08
