Results 1 to 10 of 16
Thread: Vectra C Caravan / Estate - higher speed strange sound
    Jul 2012
    PL
    Default Vectra C Caravan / Estate - higher speed strange sound
    Hi,
    well, now tricky question : strange sound - something like rubbing, not so noisy - seems under bonnet - when speed achives about 55mph and more - any common/standard reasons ?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    what make are your tyres ?
    http://www.vectra-c.com/forum/showth...light=dronning
    what engine do you have ?
    Jul 2012
    PL
    I don't think so tyres cause the problem - it's another kind of sound
    engine is 1.8 petrol
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    Quote Originally Posted by gmx View Post
    whats the mileage and year?
    what are the make of the tyres?
    and how much tread is on the tyres ?
    Jul 2012
    PL
    about 140,000 miles ; 2004
    I don't have so many miles on these tyres (dunlop winter sport) - and it's another kind of sound - strange sound started after driving quite fast about 1,5h and now exists when the speed achives about 55mph and more)
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    have you checked the wheel bearings means its done 140000 miles?
    does it do it when your in gear ?
    Jul 2012
    PL
    recently car service (maintenance) has been made on about 130,000 miles, now is done about 140,000 - (I didn't check bearings now) - it seems that sound source is under bonnet but not from wheels;
    (car is in gear (e.g. 5 and and I don't change gear))
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    cambelt and waterpump done?
    at what mileage?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    check post 7 and 17
    http://www.vectra-c.com/forum/showth...wheel+bearings
    i would get the wheel bearings checked then
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    i had i strange sound on mine for quite some time, turned out to be a wobly rear disc... when replaced then all is fine.
  1. Vectra C Caravan / Estate 1.8 petrol - what battery do you use ? (Ah, CCA (EN))
    By gmx in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2013, 21:22
  2. Vectra C Caravan / Estate - what is that plug, where it should be connected ?
    Last Post: 14th February 2013, 23:51
  3. Replies: 6
    Last Post: 29th December 2012, 17:32
  4. Vectra 1.8i VVT Estate for towing caravan???
    By fastbatard in forum Introduce yourself.
    Last Post: 26th November 2010, 11:54
  5. steering wheel judder when at higher speed
    By bunsen1 in forum Suspension, Wheels & Brakes
    Last Post: 29th August 2010, 15:36
