Thread: Vectra C Caravan / Estate - low pressure in windshield washer nozzles
    Jul 2012
    PL
    Default Vectra C Caravan / Estate - low pressure in windshield washer nozzles
    Hi,
    I have low pressure in windshield washer nozzles (washer fluid achives about 10cm) but the rear one works fine. Any ideas ?
    gmx
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Partial blockage in pipe work. Or nozzle
    ask a garage to use blow line down from the jets and should clear it
    Jul 2012
    PL
    yea, I think can be more pipe problem than nozzles (I have same effect in both) -
    has anybody pictures how pipes are connected inside ?
    Jul 2012
    PL
    and additional question - if I will blow it down (from nozzle side) how high can be the air pressure which is safe (and don't destroy the system) ?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Jul 2012
    PL
    yea, thanks a lot - it describes procedure quite well - now just to try it
    Jul 2012
    PL
    btw: one question more: if that washer pump has 2 outputs - does it mean the filter is mounted 'on input' and if I have effect only low pressure in windshield washer nozzles (not in rear one) it is more problem in piping under way 'washer pomp' - 'windshield washer nozzles' ?
  1. Vectra C Caravan / Estate 1.8 petrol - what battery do you use ? (Ah, CCA (EN))
    By gmx in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2013, 21:22
  2. Vectra 1.8i VVT Estate for towing caravan???
    By fastbatard in forum Introduce yourself.
    Last Post: 26th November 2010, 11:54
  3. washer nozzles
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2009, 23:32
  4. Heated washer nozzles
    By Ste in forum Bodywork & Interior
    Last Post: 3rd April 2007, 14:18
  5. Heated windscreen washer nozzles?
    By stevedee3 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2006, 03:00
