Results 1 to 10 of 19
Thread: Another DPF Thread
    Oct 2010
    burnley
    Default Another DPF Thread
    Hi I know there are some threads on DPFs but I just wanted a bit of clarity if possible?
    Ive been getting a smell of burning diesel/ more like paraffin in the cab occasionally and when I am coming to a standstill the car is juddering badly and the revs bouncing. Is the DPF trying to regenerate? I've no lights on the dash and no smoke from the back. The smell is so potent I have to open the window. It happens a day after I fill up with diesel usually.
    I have a 1.9cdti 150 auto vectra c 07 plate
    cheers guys
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like it, take the car out for a blast up the motorway and see if that clears the symptoms - ie let the DPF perform a regen. If there is someone local to you with Vaux com maybe they can do a forced regen for you possibly. Ultimately get the DPF mapped out and removed.
    Oct 2010
    burnley
    Thanks for that. It's just the no lights, no smoke and I meant to mention no fault codes that's throwing me.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    104 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    You shouldn't get a diesel smell with a functioning DPF, even during regen, unless something is faulty. But without hooking up an opcom or tech2 whilst it is misbehaving I don't really know what's going on here.
    The only time I've encountered a diesel smell and rough running was when the return pipe from the injectors to the pressure regulator or whatever it is was leaking. But that doesn't explain why it only occurs a day or so after a refuelling.
    Oct 2010
    burnley
    Ye it's a strange one. It's now occurring more regularly, 3 times yesterday. Possibility of a stuck EGR valve?
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by paulcoates View Post
    I had problems with my EGR Valve, I unplugged mine and was running much better, could be worth a try.
    Oct 2010
    burnley
    cheers for that ill take it to the garage and get him to look. its never ending this problem!
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    unplugging the EGR can cause to much heat to the turbo can also cause turbo fail
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by Vectra-c-SRI View Post
    How much truth is in this?
    Why have so many people had their EGR's mapped out if this is the case?
    Are there any known issues with the turbo?
    Dave
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Sebastian B View Post
    Dave
    Actually it would run cooler with the EGR valve blanked BUT but I would imagine it running cooler means the regen would be incomplete or not effective. . The EGR valve on a diesel raises temperatures as it causes the mixture to run rich. Petrols run hotter the leaner the mixture, diesel run hotter the richer the mixture.
  1. where has my thread gone?
    By daddycool in forum General Chat
    Last Post: 12th June 2011, 18:53
  2. Another EGR thread, lol.
    By sgandtg in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 20:33
  3. It's an old thread.
    By Stevel in forum The 'Off Topic' room
    Last Post: 11th November 2008, 19:39
  4. Bring back the Krays (thread split from scam thread)
    By VauxVeteran in forum General Chat
    Last Post: 26th July 2006, 09:58
