Results 1 to 2 of 2
Thread: Battery
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Default Battery
    Need help! How do I test to find if something is draining my battery using a multimeter?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Put it into amp mode disconnected the neg lead and fit multimeter in series.
    you then need to allow time for things to go to sleep etc
    common faults are boot light/ glove box lights. Or computers that keep "waking up"
    ypu can check for parasitic drain by check mv draw across each fuse but its bit more complicated
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Key fob battery
    By Fausty in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2011, 02:38
  3. Battery
    By Wolfie01 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 23:52
  4. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
