Thread: Ncdc2013 help
    Aug 2012
    Chesterfield
    Default Ncdc2013 help
    Can I fit a ncdc2013 with screen from a car with no climate control to my gsi with climate control
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    174 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Is your car a pre-facelift (half can) ? Did the 2013 and screen come "together" from another car, or did you collect them from different cars ?
    If preface/halfcan and they came together, then I suspect the answer is yes !
    Just "do it", and see what happens. The worst that can happen is that it doesn't work, if it works but doesn't recognise climate control, then it may just need a tech2 session (or a "guru" ).
    Good luck m8
    Aug 2012
    Chesterfield
    Ok thank you
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes you can.. just need to "tech2" out the setting about the climate control in the screen, and 2 wires you just have to not put to the ECC but to Screen instead
    Aug 2012
    Chesterfield
    Quote Originally Posted by kenp View Post
    what if the screen is from a 2.2 dti and going in a 3.2
    Engine : 2.2 Direct
    Still not a problem, just need to change the codeindex (better be done with a tech2)
    Aug 2012
    Chesterfield
    Thank you for You're help mate
  1. What does the GID look like with a NCDC2013?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2010, 21:57
  2. NCDC2013 add on for MP3
    By malk in forum Electrical & ICE (including SatNav)
    Last Post: 22nd April 2010, 17:49
  3. ncdc2013
    By billyyoung in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2009, 21:52
  4. Ncdc2013 + gid
    By bigmac in forum Parts for sale
    Last Post: 4th September 2009, 13:21
