Results 1 to 3 of 3
Thread: Vibration/Rattle noise near behind R/H headlamp/Grille
    Regular Member vxinsigniaboy's Avatar
    Monmouthshire
    Default Vibration/Rattle noise near behind R/H headlamp/Grille
    60plt 130 cdti SRi
    Ever since new I've had a vibration/rattle type noise at tickover from the R/H/F area behind R/H headlamp/Grille area.
    Having done some 38k its getting louder, yet cannot trace it even with bonnet open holding/pushing various things IE Cambelt cover, Air intake items, headlamp, grille and other things in that area with no joy.
    Recently had a service and mentioned about this noise and dealer without listening said "its the Turbo valve rattling and it needs a kit fitted" ???.
    Today I had this Turbo valve kit fitted and guess what, the noise is still exactly the same.
    My cousin who has the same model has no such noise or a few others I've listened to.
    Has anyone experienced a similar noise.
    thanks
    Monmouthshire
    OK.
    Been back to dealer today and asked if we were getting crossed wires about this noise as they jumped to conclusions about the noise tobe the Turbo valve.
    Today the supervisor came out to listen to noise I was referring to, and told its the air intake pipe behind behind bumper from air filter vibrating against behind bumper. Bumper tobe removed and some wrapping applied.
    Another fault has come along since service, this maybe from the investigation into the noise or maybe a software update. At approx. 2000 rpm in 6th gear on motorway intermittently, it suddenly dies with loss of power for a second or two then back to normal over a 300 mile trip it happened 3 times.
    Its not Turbo lag and its only since the service...
    This also is tobe checked out again with the air intake pipe.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    have you jusr recently had the software update
    as im sure they have suspended the most recent update and are releasing a new one around the 18th january
    the old update will most likely be causing your problems get back onto your dealer to confirm new update as some dealers know about it and others dont
  1. Vibration Noise under speed
    By ianplant85 in forum Troubleshooting
    Last Post: 9th January 2012, 19:42
  2. Vibration Noise - Wheel Bearing?
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 9th September 2011, 12:36
  3. slight droming and a very little vibration noise.?
    By signum driver in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2011, 10:32
  4. Low rumble/vibration with 'sneezing' noise
    By David Shouksmith in forum Engine & Drivetrain
    Last Post: 17th November 2009, 21:10
  5. vibration/noise
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2008, 08:26
vibratiing vectra headlight on
