Thread: Bit of a stupid question how do you bridge things :(
    Dec 2012
    Banbury
    Default Bit of a stupid question how do you bridge things :(
    Hello, how do you bridge a radiator fan never done it before, so I take it I get a piece of wire, does it matter what wire it is? And then I in plug the fan connector and put the wire on one of the pins does it matter which one? And connect the other side up to the positive side of the battery ?
    Just need to see if its working so I can eliminate it as not working currently
    Dec 2012
    Banbury
    Anybody ??
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    One to ground one to live find the ground onbthe fan will be brown then black is live
    milton keynes
    What problem are you having non-functional , intermittant or constant?
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    At a guess seeing if he has a short in his cableing i woukd guess
    Dec 2012
    Banbury
    Eml on and car gets very hot and doesn't cut in and my fuse popped, the fan doesn't feel right when I spin in moves freely but feels kinda stif to me :s going to check all the wires and the relay tomorrow and bridge the fan to check it actually works and hopefully figure out what's wrong as I need the car on the road
    could it just be the relay ?
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Short on the cable mate in that case
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Disconnect fan and run your own good power and ground (fused wire for safety) to ensure it runs correctly.
    You then need to search for the short. This is the hardest type of electrical fault to find.
    But a lot can be found by basic hand and eye checks of the loom and connectors.
  1. One of those Stupid Things....
    By GazVXLINE170 in forum The 'Off Topic' room
    Last Post: 17th June 2010, 14:55
  2. Probably a stupid question but here goes!
    By oxenburger in forum Engine & Drivetrain
    Last Post: 10th November 2009, 01:20
  3. stupid question but...im stupid..
    By nicj in forum General Chat
    Last Post: 18th March 2009, 23:00
  4. Stupid People Doing Stupid Things
    By Jay Kay 313 in forum Comedy & Humour
    Last Post: 15th November 2007, 08:56
  5. stupid stupid stupid question- 3.0dti badge
    By Adamdavi3s in forum Styling
    Last Post: 17th August 2007, 06:32
