Thread: H7 SMD LED Bulbs
    Regular Member Carl83's Avatar
    May 2011
    Basingstoke, Hampshire
    Default H7 SMD LED Bulbs
    Hi has anyone used some of these for their headlights and/or full beams?
    Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item...d=251172147895
    Carl
    Sent from my Samsung Galaxy SII using Forum Runner
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    They're crap, not bright enough! I've got some of these http://www.ebay.com/itm/2-H7-CREE-LE...dcf5b8&vxp=mtr and still they're not bright enough for night driving.
    There's a fair ammount of work involved in getting these to work properly as they will flash periodically with the bulb check making your car look like the headlights are flashing alternatively which is bad. I've currently got a circuit on test which needs a few little touches to finish off which will stop the LED lighting when the bulb check pulse is sent but still register that there is a bulb there so there'll be no error. When the test is complete they will be going in the full beam.
    11 Post(s)
    Hmmm, LEDs. They'll flicker just like any other LEDs fitted to the Vectra.
    I see from the ebay ad that the lumens rating is 400.
    To give you some idea how dim that'll be:-
    A standard 55 watt halogen bulb emits approx 1100 lumens.
    A 35 watt 6000k HID bulb emits approx 3200 lumens.
    In short, they'll be approx a third the brightness of standard halogens.
    May 2011
    Thanks mate, I will save my money then.
    Carl
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  3. 80w bulbs
    By wullie-t27 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 11:00
  4. LED bulbs
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 09:47
  5. Bulbs!!!
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2007, 14:22
h7 led bulbs for vectra
