Thread: CDTI Fuel filter issues
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    Default CDTI Fuel filter issues
    I've recently had the fuel filter changed on my 120 8v cdti.
    It then began to weep, so a tightened it up alittle.
    Still it weeps so it was tightened til it cracked!!!
    FFS!!! £110 later a brand new genuine filter housing ready to fit was placed in along with the new blue fuel line bits...
    Its now leak free but on cold start in the morning its taking longer to fire???
    Is there something I've done wrong, is there seals in the housing or something?
    Pressuming its getting air in which is causing the cold start issue which wasn't there before we touched the filter?
    Mar 2012
    cheshire
    11 Post(s)
    Bttt, still doing this on first crank in the morning only.
    Only happened since putting complete new housing on.
    Mar 2012
    cheshire
    11 Post(s)
    Help...
    East Ayrshire
    Trim : SRI XP1
    When you turn the key do you leave it a few seconds with the dash illuminated before trying to start it? It might be that the fuel is filtering back towards the tank, doubt it tho
    Admin plasma's Avatar
    On the Forum
    321 Post(s)
    Engine : 150
    Mileage : 74000
    try this... turn on the ignition and wait, listen to the noise coming from the fuel system, see if u can hear air being blown back into the fuel pump it will sounds like a bubbling noise, if it is then theres a slight airleak somewhere..
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Mar 2012
    cheshire
    11 Post(s)
    Will try above when her indoors is back with the car lol.
    I bought a full new unit from Vauxhall and plugged it in.
    Where the outlets are in the housing is there any rubber 'O' rings down them, wondering if theres one missing on the new one or maybe one off the old one thats now down the hole of the new one?
    Its gotta be something to do with the pushfit connections imo, not touched powtb else.
    This is what preventative maintainence does, was fine before, just the filter was rammy!!! lol
    Mar 2012
    cheshire
    11 Post(s)
    Still having issues.
    I've had fuel pipes back off the filter yesterday, both look to have the same seals down them.
    Dunno if anyone has a pic of there fuel pipe fittings, and pics of the fuel filter inlet and outlet holes.
    The wiring plus on the top and the bottom of the housing. What do these both do?
    This was not a issue before I fitted this new housing. Could the electrical side of the housing be faulty???
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by Slammedorion View Post
    Image found on C-Owner forum
  1. CDTi Fuel Filter
    By Homer in forum Engine & Drivetrain
    Last Post: 17th November 2012, 23:15
  2. Oil and fuel filter 1.9 cdti 150
    By chay6684 in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2012, 08:07
  3. Cdti fuel filter
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 3rd September 2010, 21:06
  4. cdti fuel filter
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 19:23
  5. CDTI Fuel filter
    By crgv6 in forum Engine & Drivetrain
    Last Post: 26th November 2009, 21:27
fuel system issues vectra
vectra c 1.9 fuel filter problems
