Thread: Horrible crunching noise during starting!?!
    Dec 2012
    Midlands
    Default Horrible crunching noise during starting!?!
    Ok, just headed over to get some fuel and all was well, after paying I moved the car round the corner to top up he air. When I went to start the car to come home there was an awful crunching noise as I tried to fire it up. I immediatly backed out and checked I was fully in nuetral... I was. Tried again, started fine.
    I was intrieged so turned it off, then 3rd time horrible crunch, 4th time, started fine so I came home worried I'd be left stranded.
    Any ideas?
    It has been a bit slow to fireup recently so I've been thinking my starter might be on the way out. Do they sound like that when they're dieing?
    belfast
    Very likely to be starter. The Bendix gear throws the starter onto the flywheel. If it doesn't engage properly, then you get crunching. Generally it's intermittant at first, but it needs fixing...
    Full Member witty's Avatar
    Jul 2011
    HALESOWEN
    Vehicle : VECTRA C.
    Trim : ELITE
    Engine : 2.0 DTI.
    Mileage : 106600
    First thing to check would be the starter...
    Dec 2012
    Midlands
    When you say 'check' do you mean replace? Is there a physical check that can be done?
    Jul 2011
    HALESOWEN
    Vehicle : VECTRA C.
    Trim : ELITE
    Engine : 2.0 DTI.
    Mileage : 106600
    Remove the starter and take a look at the bendix gear to see if there are any teeth missing or a worn gear...
    Dec 2012
    Midlands
    Oh, I see. Will do this first. Cheers.
    Dec 2011
    Seaham
    Could also bedueto a failing battery. As you do not have the power to throw the bendix in cleanly. Also check your battery and all connections to the starter motor.
    Dec 2012
    Midlands
    Mini Update, hasn't ahppened again since this incident (twice in 3 cranks) so might be due to what happened immediatly before the incident. On my way to the petrol station I was driving down country lanes when around 1 corner I was presented with a flooded road. I hit it quite hard, water everywhere. May be a bit of water got in/around the starter causing the issue? I don't know but starting fine at the moment (albeit a little longer cranking than I'd like). I'll keep my fingers crossed.
    Thanks for the suggestions.
  1. Horrible crunch noise when starting?!?
    By ficosaneil in forum Engine & Drivetrain
    Last Post: 28th December 2012, 22:02
  2. Crunching noise +ARB bushes
    By FrenchConnection67 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th December 2011, 00:43
  3. Crunching Noise
    By Decker in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2010, 01:31
  4. Rear crunching noise?????
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2007, 19:09
  5. Crunching noise
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 21:55
